Throttle and Idle Cables
Old Aug 4, 2009 | 09:40 PM
20FXST06's Avatar
20FXST06
Default Throttle and Idle Cables
Do the these cables just pop out of the switch housing or are they held by a clip or something. Can't seem to get mine loose. Help!!
Old Aug 4, 2009 | 10:37 PM
MNFatboy's Avatar
MNFatboy
I have an 05 Fatboy and mine just came out with a quick tug.
Old Aug 4, 2009 | 10:42 PM
m i k e's Avatar
m i k e
drop a tad i mean a tad of oil on there
(from inside)(or outside upside down )
then grab and slightly bend back n forth
you'll get em
Old Aug 4, 2009 | 10:45 PM
BLKnCHRME09Deluxe's Avatar
BLKnCHRME09Deluxe
mine had a little c-ring on the inside which fit into a grove on the cables but i just tugged on it also and it popped right out. But then installing the new ones in was kind of a tedious 15 minutes getting the new rings back on to the new cables. Good Luck
Old Aug 4, 2009 | 10:55 PM
theiceman's Avatar
theiceman
i have a set of cyclesmiths 13" apes in my 2007 flhx.i have a bad rotating cup for a couple of years allready.if i switch to 10" can i still use all the cables from the apes providing i tuck them really nice inside the fearing?please help!
Old Aug 5, 2009 | 07:04 AM
tk353's Avatar
tk353
loosen them first and they should fall out when you open the housing. be ware of the little brass barrel that will fall out. when you raise the cable to vertical there is a slot and the barrel cones out.
Old Aug 5, 2009 | 09:21 AM
bensonjv's Avatar
bensonjv
You can probably reuse the cables. Excess cable can be as bad as too little with big arcing loops and kinks but you should be ok. Throttle shouldn't be too bad, brake lines won't matter much. Clutch cable is your biggest concern. Depending on how much excess you have you may find your cable squeeze is harder. But as long as it returns freely and isn't binding its nothing to worry about. My guess your biggest problem will be aesthetics.
Old Aug 5, 2009 | 09:26 AM
bensonjv's Avatar
bensonjv
Yes they pop out and there are no other screws, bolts, etc holding them in place. As others mentioned, they are held in place with small "c" clips that use friction and pressure to stay in place. Once you loosen the cable tensioners and have slack in the cable you should be able to pull them free from the housing and then remove the ferrule ends from the grip. It takes some force but as some have suggested, some lubricant (WD40, silicone, lite oil, graphite...) can help some.
Old Aug 5, 2009 | 08:59 PM
theiceman's Avatar
theiceman
thak's for the info,the dealer order the cables "plus six" i think they are refering to stock lenght plus 6 inches
Old Aug 5, 2009 | 11:01 PM
bensonjv's Avatar
bensonjv
Correct.
OldTyme
Sep 12, 2012 09:29 PM
elcamino
Exhaust System Topics
Mar 14, 2008 09:01 AM
jcboof
Feb 9, 2008 11:02 PM
NYSportster
Jan 14, 2008 12:12 AM
FD2
Aug 29, 2006 07:55 PM
