Front End Clunk??
Old Aug 9, 2009 | 09:31 PM
ajpuck's Avatar
ajpuck
Question Front End Clunk??
I have a 2006 Fatboy. I had the dealership chrome the front end and put chrome calipers on it too. Sometimes when I go to stop I hear a "clunk" from the front end. Anyone have any suggestions as to what might be causing that "clunk"??? Thanks!
Old Aug 9, 2009 | 10:04 PM
RocketRocker's Avatar
RocketRocker
I wont BS you...never had to deal with this. I would do some common sense stuff though.....check cable tension, check cable housing to make sure it aint to loose or not guided through the retainer thing, check tightness of all bolts on caliper, have someone engage f brake while I look at it to see if its contacting anything. Once I've done all that.....I would call my bro for some cheap advice.
Old Aug 9, 2009 | 11:30 PM
Chazmanian's Avatar
Chazmanian
R.I.P. BROTHER
Take it back to the dealer and have them check the fall away/ Head bearing adjust.
That "Clunk" is typically the head bearings. What you are hearing is the shaft clunking as the top bolt that squeezes that whole deal together is too loose.
Easy fix.
Old Aug 10, 2009 | 11:41 AM
tk353's Avatar
tk353
bearings or motor mount
89FLHTC
EVO
15
Nov 2, 2015 12:15 PM
michaeltam2k
Oct 25, 2015 11:44 PM
Scudda
Dec 13, 2013 11:09 AM
ahhwataday
Feb 14, 2012 06:39 AM
tcartwr332
Aug 30, 2007 02:09 PM
Top
© 2026 MH Sub I, LLC dba Internet Brands
Follow Us
