Does Roadking windshield fit FL front end?
Old Aug 12, 2009 | 12:20 PM
128auto's Avatar
128auto
Default Does Roadking windshield fit FL front end?
Do I need a windshield? No way! Do I need a sound system? Yeah! I found a detachable batwing fairing w/4 speakers audio system on local craigslist, it is off a 04 Roadking, the seller said it should fit the FL front end, does anyone know? It doesn't come with docking hardware so I have to make it work. Thanks!
Old Aug 12, 2009 | 12:27 PM
XARAN's Avatar
XARAN
The FLS (Softail) front forks are a couple of inches narrower than the FLH (Touring) so it probably will not fit wit out some modification. Im sure it can be made to work.
Old Aug 12, 2009 | 12:33 PM
128auto's Avatar
128auto
really? have to look for something else then, thanks
Old Aug 12, 2009 | 10:01 PM
Yosemite's Avatar
Yosemite
Actually, the FLH and FLST front ends are 1/4" different on the width with the softail being narrower. The big problem is the side mounting bolts which can be as much as 2" different as the spacing between the upper and lower triple trees varies quite a bit.
My fairing is off an older FLH and all I had to do to make it fit was adjust the spacer on the slip on mounting grommets and have a piece welded into the lower bracket leg to stretch it enough to hit both mounting grommets.
Take a look at who made the fairing... If its an aftermarket, call the dealer and see if they sell the brackets for your model bike. Could be simple as that... otherwise, fabrication works well too.
But trust me, it WILL fit.
hubcap
EVO
May 3, 2015 06:43 PM
patcham48
EVO
Jun 19, 2013 07:48 PM
emwolb
Sep 24, 2010 04:16 PM
Yosemite
Aug 30, 2009 07:43 AM
sportyguy69
Sep 20, 2008 08:57 AM
