88B Softail Motor Question
Old Aug 15, 2009 | 04:06 PM
kentuckydave's Avatar
kentuckydave
Default 88B Softail Motor Question
What causes an 88B motor to drain the oil down into the crankcase and how is it repaired? Is it something a decent "shadetree mechanic" can fix or does it have to go to the shop? I know my way around car motors but don't know sic'em about motorcycle engines.
The wife's '01 Fatboy will drain down if left sitting for two weeks. It can't be a good thing and I know it must be hard on the starter with it having to pull the crank through all that heavy oil.
Any assistance would be appreciated.
Old Aug 15, 2009 | 04:26 PM
agapsdiver's Avatar
agapsdiver
It's normal.
Old Aug 15, 2009 | 05:02 PM
Chazmanian's Avatar
Chazmanian
R.I.P. BROTHER
Find a service manual and do a sumping test on the bike. Once running there should only be X amount in the crankcase. The typical culprit seems to be a faulty ball check valve deal.
Never thought about it filling the case or wet sumping whilst it sits tho?
Old Aug 15, 2009 | 08:30 PM
WARG's Avatar
WARG
Mine does it too. All the research and questions I've asked have lead me to believe it's pretty common because of the oil tank being suspended above the crank case. As long as the oil comes back up when you crank the bike, don't sweat it.
Old Aug 16, 2009 | 01:16 AM
ChromeJunkie's Avatar
ChromeJunkie
Start it up and let it run for a few minutes, then check the oil. If the level is ok, then you are good to go and don't worry about it.
Old Aug 16, 2009 | 04:22 AM
mplecha's Avatar
mplecha
to check for a sumping problem, get the oil to around 200* (operating temp). shut the bike off and remove the plug in the bottom of the crankcase. you should get around 4 ounces. be very careful putting that plug back in. you don't want to crack your case.
Old Aug 16, 2009 | 05:15 AM
hpfatboy's Avatar
hpfatboy
As far as i know, all the HARLEY motors do this. Checked oil tonight for ride tomorrow, and oil doesn't even register on my dipstick. I'll fire it up tomorrow and give it 5 min. and then check it, im sure it will be right on as usual. Just dont consider it low when COLD and add more oil, then you will be in TROUBLE WHEN IT WARMS UP!!!
Old Aug 16, 2009 | 10:43 AM
kkinderen's Avatar
kkinderen
This is how the shop told me to check the oil. When I put it up for the night check it out. In the morning, if there's not a pool of oil on the ground then your good. A few minutes of running will get the oil back up in the tank. It surprised me the first few times to see the oil tank empty in the morning. I don't worry about it anymore.
Old Aug 17, 2009 | 09:31 PM
kentuckydave
Thanks for the replies. The thing did not do this up until the past few months. Must be a check valve somewhere that is stuck open. Anyway, if it is this common of a happening I will not worry about it.
I fouled up a month back and added oil before I though about it much. I got to thinking about it before we started to ride. I started the engine and up came the oil in a hurry. I shut it back down and I had to suck the oil out of the tank with a cooking baster to get it back down the correct level. I would of had oil all over the place if I had of let it run more than a few seconds.
Thanks again for the responses.
dcarp444
EVO
19
Jul 26, 2019 08:50 AM
zach smith
Engine Mechanical Topics
Aug 5, 2015 11:49 AM
janiharley1
Oil Archive (no new posts)
May 16, 2015 12:42 PM
AIRBORNESNIPER
Exhaust System Topics
Jul 7, 2007 02:22 PM
fergerburger
Jul 5, 2006 06:14 PM
Top
© 2026 MH Sub I, LLC dba Internet Brands
Follow Us
