2010 Heritage Valve Clatter
Old Aug 16, 2009 | 09:00 PM
Man In Black's Avatar
Man In Black
Default 2010 Heritage Valve Clatter
Just picked up my new 2010 Heritage Softail six days ago and have 200 miles on it. I have ( HEAVY ) valve chatter in mid gears, mostly in third or fourth when letting off of the throttle and applying light throttle again while moving in traffic at about forty miles per hour. The chatter goes away when you give it more throttle. The bike has only 200 miles on it and has went through twelve gallons of fuel and the dealer tells me that these things are normal. I have been riding Harleys all of my life owning about thirty of them, this being my fourth new one and never had this problem. The last bike that I traded in was a 2002 Night Train and the engine was quiet and got good gas mileage. I always use premium fuel and tried different brands. Any opinions on why it is using so much fuel and valve Chatter? Someone suggested the engine curve is out of adjustment. I understand that these fuel injected bikes don't have timing adjustments. Any advice from Harley mechanics would be appreciated.
Old Aug 17, 2009 | 04:36 AM
jimmers1817's Avatar
jimmers1817
So the dealer is telling you that it's normal for your bike to get 16 mpg. I think I'd take it to a different dealer. You should be getting 40-50mpg from that bike.
Far as the noise goes, hard to say. I have an 08 Heritage and it's got valve clatter also. Never paid much mind to what gear or speed I get it at. Hear it more at some times than others.
I took a 2010 for a demo last week and really can't say I noticed anything different in the valve noise.
Old Aug 17, 2009 | 06:50 AM
Skitzer's Avatar
Skitzer
I also have an 08 Heritage. A little valve chatter is normal especially with quiet mufflers. I put V&H pipes on mine and don't hear the chatter hardly at all anymore.
Your gas mileage sucks ....... something definitely wrong there. I agree with jimmers ..... take it to another dealer. Does it blow smoke?
Old Aug 17, 2009 | 07:49 AM
Man In Black
No there is no smoke at all. thats what is baffling, it's like it just disappears, and the valve chatter is not slight, the valves are banging so hard that it seems like it would do damage if I continue to run it. I'm going to nurse it back to the dealer this morning around 10:30
Old Aug 17, 2009 | 11:13 AM
jimmers1817
Yea, like someone posted elsewhere, they tell it's normal until it's out of warranty, then it's $3000 in repairs.
Old Aug 17, 2009 | 11:18 AM
Man In Black
Default Chatter appears to be normal
I went back to the dealer today to ride another new Heritage and it has the same clatter , so I assume that what they are telling me about these engines is true. Everyone that I talked to say it is just a characteristic to the twin cam engine that is just heard more with the quiet stock exhaust. They are still working on trying to find out why it is using so much fuel. If anyone would like to comment on their experiences with their Heritage, I would appreciate hearing from you.
Old Aug 17, 2009 | 12:27 PM
rbabos's Avatar
rbabos
If it clatters just reving the engine while sitting still, then it could be the lifters. There's a lot of bad ones out there that dealers won't fix.
If however the engine is sounding normal while reving it in the parking lot, your issue is most likely the compensator if it only happens at certain load conditions and gears. Lifters don't care if the engine is under load or not and will behave the same in both situations. In 19k I've never heard valve clatter once, but did toss the stock comp long time ago. The sound is similar to valve clatter when you have a bad one.
Ron
Old Aug 17, 2009 | 09:33 PM
TexFordD's Avatar
TexFordD
Dump the factory oil and go synthetic. see if the noise is the same
Old Aug 17, 2009 | 09:54 PM
klaybus's Avatar
klaybus
I have an 08 Heritage too & I also have a little valve clatter....I thought that was a HD trademark....Enjoy the ride!
grumpy350
Aug 7, 2011 12:49 PM
MX Mark
Dec 1, 2010 09:44 AM
Propcut
Jul 23, 2010 11:40 AM
Man In Black
Oct 25, 2009 12:13 AM
thehueg
Aug 22, 2008 08:10 AM
