hard to shift into neautral
Old Aug 18, 2009 | 08:29 PM
fatking's Avatar
fatking
Default hard to shift into neautral
got a question, i changed my oil from standard harley oil to amsoil and its harder to shift gears and shifting into neautral is even harder. i put 10w40 in the engine primary and transmission. should i have used a different weight for the transmission and/or primary? thanks
Old Aug 18, 2009 | 08:36 PM
lightweight bob's Avatar
lightweight bob
Yep, 10w40 is OK for your primary - MOCO sold it for years as primary oil. Your tranny
will like 75w140 synthetic - I use Redline but Mobil 1 is also very popular. Also, be sure
you didn't overfill the primary - it will cause problems finding neutral.
Old Aug 18, 2009 | 08:54 PM
fatking's Avatar
fatking
thanks i will get some to try
Old Aug 18, 2009 | 09:30 PM
oct1949's Avatar
oct1949
depends on what yr bike U have,,!!!
I don't like changing the primary oil if not having an issue...
the 88's and the 96's tranny's have different requirements and makes the need of different oils desirable. the 88's are fine with 75-90GL and the 96's with the 5th whine sometimes needs the 75-140 GL oils
motor is usually better with 20w-50 weight..
Brand of oil is Ur choice.
Old Aug 19, 2009 | 04:45 AM
hpfatboy's Avatar
hpfatboy
2ND THAT, using 10-40 AMSOIL primary, 75-90 AMSOIL gear lube tranny.
Old Aug 19, 2009 | 07:13 AM
tk353's Avatar
tk353
I use Bel Ray for the trans and no wine or clank and I can find neutral. I use Motor FactoryŽ Primary Case Lube in the primary. because Amsoil has gone up so much I just switched to Mobil 1 for vtwin and it works as good. I have 39,000 miles in about 2 years and it runs great and no debris in the oil changes.
http://www.belray.com/consumer/product.fsp?pid=13637
http://www.customchrome.com/dcm/cc/view.asp?mfoil.html
Old Aug 19, 2009 | 08:20 AM
Dustmaker's Avatar
Dustmaker
Amsoil in mine with no problems. How many miles you have on your scoot?
Old Aug 19, 2009 | 10:39 AM
softail04's Avatar
softail04
mobile one 20/40 in both engine and tranny regular oil in primary. no problem to day and 45 thou. miles on 04 std.
Old Aug 19, 2009 | 11:34 AM
qwispichkn's Avatar
qwispichkn
I use HD stock and have no problems except neutral is a little hard to find sometimes.
DougYITBOS
Sep 16, 2012 04:16 AM
Figstr
Jan 24, 2012 12:01 PM
Tropical Andy
Jun 6, 2010 08:29 PM
robswglide
23
Feb 19, 2008 07:40 AM
FBFletch
Oil Archive (no new posts)
Jun 8, 2006 01:20 AM
