Springer Front Turn Signal Relocation
Old Aug 24, 2009 | 09:10 PM
04Springer's Avatar
04Springer
Default Springer Front Turn Signal Relocation
Need just a little help. Searched but the photos just aren't giving me what I need. Using the Drag Specialties Relocation Kit (2020-0024) for my Springer, I cannot tell if the little bracket with the "rotating ball" stays on or if it comes off and just the signal mounts on. If the bracket stays on, then I will need to go get a nut to match the mounting bolt it came with. If its just the light, it seems like it doesnt mount flush to the bracket and maybe someone could shed a little light on that.
Either way the info is helpful.
I question this because the nut I seem to need didn't come with the kit. If I had the same acorn nut that holds the mirrors on, it would seem to work as well. But the kit came with nothing.
Old Aug 25, 2009 | 12:19 PM
04Springer's Avatar
04Springer
Mid-day bump prior to going to the hardware store....
Old Aug 25, 2009 | 01:53 PM
jrspringer06's Avatar
jrspringer06
I believe you just mount the turn signals. 5/16 fine thread bolt is what the bullets are tapped for.
Old Aug 25, 2009 | 02:30 PM
travis dasher's Avatar
travis dasher
Bracket with rotating ball comes off and the turn signal mounts to the relocation bracket.
Old Aug 25, 2009 | 07:47 PM
04Springer's Avatar
04Springer
Cool thanks guys!!
PistolPete83
Dyna Parts
Feb 5, 2013 11:04 AM
lcnab155
Electrical/Lighting/Alarm
Jan 9, 2012 02:03 PM
jaysonL
Jun 28, 2009 05:11 PM
kiddoc
May 26, 2007 11:08 PM
