Should this be happening?
Old May 4, 2005 | 01:50 PM
Bad Guy's Avatar
Bad Guy
6th Gear
Default Should this be happening?
Bought my brand new 2004 Fatboy in Oct 04. I have had it garaged all winter and only have 600 miles on it. The rear stock wheel is all oxidized on the caliper side. Took it to the dealers yesterday and they are telling me that they will try to have it put thru the warranty but I should not get my hopes too high since it is probably due to the temp in my garage. I told the dealer that was unacceptable. I have had my other bike in this garage for the last 6 years and there is not an ounce of rust on it anywhere. What do you guys think - should I fight this? They tried cleaning it with pigsnot but it didn't look any better. Any help is greatly appreciated
Bad Guy
Old May 4, 2005 | 05:37 PM
SPRINGER's Avatar
SPRINGER
Default RE: Should this be happening?
If I had spent that kind of money on a bike, I would definitley see what could be done about it, even if it meant getting a second opinion from someone else. With that kind of money invested, I think that something could be done to help you out. Good Luck
Old May 4, 2005 | 06:34 PM
AceArt's Avatar
AceArt
Ask for the name of the Manufacturer's Rep. or Zone Manager or whoever is between them and Harley. I've had to do this a couple of times with cages and as soon as I ask or make one phone call or letter, everything seems to magically get taken care of almost immediately.
Their attitude is usually, We've sold hundreds of bikes before and never had this problem...must be your fault. Factory reps are more familiar witht the big picture and often say yes, it's rare, but we've seen it before...go ahead and fix it.
Hope it all gets resolved for you. Art
Old May 4, 2005 | 10:55 PM
Dana's Avatar
Dana
6th Gear
is it just the outside polished part thats oxidized? if so use wenol on it, it will bring it back
Old May 4, 2005 | 11:07 PM
Bad Guy's Avatar
Bad Guy
6th Gear
Thanks all for the responses - Dana I did tried the wenol but it didn't work.
Old May 5, 2005 | 05:06 AM
jtfrog's Avatar
jtfrog
I say fight it and dont take no for an answer. That seem's unacceptable to me.
Old May 5, 2005 | 09:12 PM
taurusjim's Avatar
taurusjim
I have an 04 fatboy and my wheel did the same but not as bad as yours, never paid much attetion to it though as i rode it all winter in the georgia mountains.
Old May 5, 2005 | 10:21 PM
mikeisglidn's Avatar
mikeisglidn
sink your teeth in their butt, till they replace it!!
Old May 6, 2005 | 01:04 AM
pococj's Avatar
pococj
This winter I had my bike, an '87 Sloptail, in my unheated shop for an extended time due to being sick and working on it. When I got over being sick and decided to go out and finish the work on it, I noticed the polished aluminum was pretty nasty. The change in temperature in the unheated shop caused condensation on the metal. Over the several weeks that I didn't stick my head in the shop the damage was done.
My rear wheel, an old '92 Sporty mag-type had more corrosion on the caliper side than it did on the belt side. I wondered at the time if it was due to the angle the bike leaned while on its kickstand. Figured the condensation was able to "stick" to that side better than the other. Took quite a bit of elbow grease to bring it back.
Something else that can contribute to severely corroding the aluminum is chemicals, especially cleaners, stored in the same room, especially an unheated room. The vapors are deposited on the surface and start their feast. If condensation can occur the problem is exacerbated by the chemical vapors being carried by the water vapor. This increases the amount of chemical being deposited on the metal surfaces.
These two reasons are probably why the HD shop told you not to hope for too much. Push it anyway as you ain't got nothin' to lose at this point. Point out that it only happened on one side of the wheel, too. Good luck!
Old May 6, 2005 | 01:39 AM
TQ's Avatar
TQ
While we are on this subject, I need some advice. My new bike has alot of chrome on it and it stays out in my 1 car garage. Its unheated but its a 6 car garage. I know that didn't make sense but I own a condo and theres 6 garges side by side, I own one. I was wondering what I could do to make sure everything on my bike stays good during the winter. Should I wipe it off once a week or... ?
