Loose Steering Head Bolt
Old Aug 29, 2009 | 08:45 PM
Heritage123's Avatar
Heritage123
Originally Posted by WFA
Hey HERITAGE123...I looked at an 07 softail shop manual today at my local dealers shop and it specifically states 35-45 foot pounds of torque to the steering head bolt. But you still should read my previous remarks . You be the judge!!!
I appreciate the heads up. I have an 08 manual (that's what they gave me when I went to buy one (said it was exactly the same for an 07 as for an 08 - he said the bikes did not change any). I see where it says to torque the upper fork stem pinch bolt 25-30 ft-lbs. But I don't see anything about torquing the fork stem bolt. It does say to torque the stem bolt to 70-80 ft-lbs on the FXST, FXSTB, FXSTC, FSCW/C, but I the FLSTC.
Old Aug 29, 2009 | 08:58 PM
oct1949's Avatar
oct1949
probably another thing that services on the bike didnt get done..
Old Aug 29, 2009 | 10:42 PM
JoeFLHX's Avatar
JoeFLHX
Had trouble after I lowered the front end. Found most of trouble was because the steering head nut was finger tight. I tighten to about 70 ft lbs. I read somewhere 100 ft lbs was now recommened but that just seemed to tight as I was tightening it.
Old Aug 30, 2009 | 06:17 AM
jimmers1817's Avatar
jimmers1817
I assumed WFA was referring to the Shop Manual, not the Service Manual we can buy. Hopefully he'll clarify.
Old Aug 30, 2009 | 10:38 AM
av8or's Avatar
av8or
Originally Posted by mike06train
You guys that use the fall away method, what do you use as a fixed pointer on the floor?
I use a homemade pointer on a srting, held up by a step ladder. I put a piece of masking tape on the front edge of the fender and made a center mark with a sharpie. I hope this helps. It is really a very easy job to do after you get your set up the first time.
Old Aug 30, 2009 | 02:03 PM
WFA's Avatar
WFA
Originally Posted by jimmers1817
i assumed wfa was referring to the shop manual, not the service manual we can buy. Hopefully he'll clarify.
My info comes from a service manual. Is a shop manual different? The one i looked at was borrowed from the hd tech. I really couldn't see a difference between the 07 manual and my 06 manual. I didn't look at an 08 manual so you are one up on me there.
As previously stated in my first response, HD service bulletin uped the torque specifications to 70-80 foot pounds for the steering head bolt/nut. That's where I run my 06 without a problem. (sb #m 1215) per instructions, I torqued first to 75 ft pounds...then set the fall-away...then lubed. I personally use lucas "red sticky #2" from auto zone. It stays put. Having said that, I'm reluctant to say more because of our bike differences. Good luck!!
Old Aug 30, 2009 | 02:47 PM
jimmers1817
I have the 2008 Service Manual and I find no torq specs for the steering head. Rather it uses the fall away method which is a PITA to do with my Heritage because of drag from the cables. Seems to get an accurate measure I'd have to disconnect all of them.
My dealer adjusted mine when I took it in for a possible wobbling problem at high speed. They said it wasn't a warranty issue and charged me $42. I doubt they used the fall away method for adjusting them. More likely they have a torq spec or do it by feel.
Old Aug 30, 2009 | 05:41 PM
WFA's Avatar
WFA
i have the 2008 service manual and i find no torq specs for the steering head. Rather it uses the fall away method which is a pita to do with my heritage because of drag from the cables. Seems to get an accurate measure i'd have to disconnect all of them.
My dealer adjusted mine when i took it in for a possible wobbling problem at high speed. They said it wasn't a warranty issue and charged me $42. I doubt they used the fall away method for adjusting them. More likely they have a torq spec or do it by feel.
Jimmers...I believe your heritage is like most other softails. That means the fall away method don't work for crap. I adjusted mine where it felt good...not binding or clunking either. But the key remains to torque the steering head bolt to spec. In my case 70-80 ft pounds. I have a friend who has been a certified hd tech in excess of 30 years and he does the fall away just as I do, period. If your hd shop did the fall away for $42 that's not a bad deal imo., especially if they cured your wobble/clunk. You can pretty well bet they used our method.
Ironically, I hang out at the hd shop with my buddy a lot but have never had them work on my bike...except state inspection. (I do solicit a lot of free advice...an occasional drink.) Fortunately, I have the ability and desire to do all of my own maintenance...so far.
Later!!
Crueltiming
Engine Mechanical Topics
11
May 13, 2019 06:03 AM
johnod
EVO
16
Feb 27, 2017 12:21 PM
jsbridgew
13
Jun 27, 2015 07:06 PM
95 Ultra
EVO
Nov 3, 2012 05:57 AM
BigJim8765
Exhaust System Topics
13
Feb 8, 2010 12:20 PM
