power cones
Old Sep 3, 2009 | 11:05 AM
jm04's Avatar
jm04
Default power cones
i own a 2004 fxst and im putting a set of big growl 2 1/4 drag pipes on it, my question is, does any of you use power cones,i just heard about them,was wondering if there something i should ad or not,i dont know if they would be to restrictive or if they are alright to put on,i need the pros and cons on these things to know to order them or not.THANKS.
Old Sep 3, 2009 | 01:01 PM
o/d's Avatar
o/d
i've been using them on my '02 fxst with vance & hines straight shots & no baffles.
originally i left the baffles in & no power cones. then i removed the baffles. after removing the baffles it felt like torque decreased.
dropped the power cones in & torque felt better.
keep in mind this is all "butt dyno" testing.
i think they work well where there's low back pressure.
Old Sep 3, 2009 | 01:29 PM
xxxflhrci's Avatar
xxxflhrci
They go in the wrong end of the pipe to do any good. If you need back pressure, look into some kind of baffle, even a cheapo shorty or homemade lollipop style.
Old Sep 3, 2009 | 08:13 PM
tmitchellof PG's Avatar
tmitchellof PG
I had power cones in my Samson,Rip Saws and they worked great.
2-1/4" is too big for drag pipes. My Rip Saws were 1-3/4" OD and I have the 103" engine. 2-1/4" should be setup for baffles. I think you are going to lose a lot of low end power running that big a diameter pipes without baffles.
Tom
Old Sep 3, 2009 | 10:52 PM
jm04's Avatar
jm04
ive been doing some reading on it and i read that some people are going to lowes and buying copper pipe reducers and putting them around 4 inches in the end of the pipes with the narrow end pointing out.would that help out at all
Old Sep 3, 2009 | 10:58 PM
jm04's Avatar
jm04
i just want good looking,great sounding pipes that wont have a power loss and doesnt cost 700 bucks
Old Sep 3, 2009 | 11:03 PM
oct1949's Avatar
oct1949
most that I've read is negative, but saying a friend has them in his 99FB with V&H LS's and he is fine with them...
chaselee
Nov 25, 2016 10:36 AM
Dragon5
Dec 15, 2009 08:13 AM
1bd99stc
Exhaust System Topics
Oct 16, 2008 09:38 AM
grunt999
Dec 16, 2007 12:05 PM
dj4016
Sep 3, 2005 12:38 AM
