Security system
Old Sep 3, 2009 | 08:17 PM
tunggruv's Avatar
tunggruv
Stage I
Default Security system
I have a 2006 Fatboy and just purchased a Harley Davidson alarm system, can this be installed at home or do I need to have the dealership install it, and if I install it does it void my warrenty.
Old Sep 3, 2009 | 11:12 PM
FATBOYUSA's Avatar
FATBOYUSA
I added the alarm on my 2008 FATBOY and a HARLEY shop has to install, they have the computer that sets the code and activate. It wasn't that expensive though.
Old Sep 4, 2009 | 12:24 AM
gforrest2's Avatar
gforrest2
I hope the one I just ordered doesn't require a dealer install. Maybe it's just the '07 and later hands free version that requires the dealer setup.
Old Sep 4, 2009 | 07:25 AM
xraybox's Avatar
xraybox
It should be doable, Pain In The A## , but doable.
From
https://www.hdforums.com/forum/touri...m-install.html
Originally Posted by AK_Hog_Herder
What? And deprive you of a valuable learning experience?
Take a look at the posts in the DIY section for Engine Diagnostics , Alarm, and Fuel Injection Issues
Some very valuable time saving info there. Armed with the correct info it may only take an hour to program. Do not forget to set a personal code that is different from the example in your book. The personal code will allow you to disarm the system using your turnsignal switches if your keyfob is lost or damaged.
https://www.hdforums.com/m_120188/tm.htm (it takes the full 30 minutes, do not be fooled when the alarm light winks out, it takes the full 10 minutes for each step, don't blink or miss your chance. If you do you must start over.)
https://www.hdforums.com/m_43975/tm.htm (still applies to 06 models)
Or spring for the HD Electrical Diagnostics Service Manual
Or haul it into the dealer and have it done with the Digi Tech.
Old Sep 4, 2009 | 08:46 PM
Driften's Avatar
Driften
From
Does anybody have the image from https://www.hdforums.com/m_120188/tm.htm ?
Old Sep 8, 2009 | 07:43 PM
gforrest2's Avatar
gforrest2
Default I must be a complete idiot - haven't even made it to the programming yet
Sorry, didn't due enough research before posting. I found the TSM. It's really tucked in there. Hopefully, programming will be smooth. I've read most of the posts on this topic. Thanks.
Loride
May 30, 2016 05:35 PM
niklndymer
Aug 12, 2009 03:44 AM
RMBLON
Jul 26, 2007 03:32 AM
nada1
Apr 27, 2007 09:57 AM
cutacroshorty
Jul 7, 2006 10:14 PM
