wheel or rocker gurus ... input please
Old Sep 7, 2009 | 02:38 AM
Rocker_Dan's Avatar
Rocker_Dan
Default wheel or rocker gurus ... input please
I'm about to splash out on some wheels for my rock and have been advised by 1 mob to go for a 3/4 inch pulley on the rear to ensure clearance, and another mob says they can make it work with a 1" pulley
the rear will be an 18x8.5 with either a metz 260(i'm told they measure less) or avon 250
Is it neccessary, does it matter and if so will it affect the bike in any way
Thanks for your input
D
Old Sep 7, 2009 | 03:35 PM
Rocker_Dan's Avatar
Rocker_Dan
Old Sep 7, 2009 | 04:21 PM
DragonSlayer08's Avatar
DragonSlayer08
Keep in mind 10 mm = 0.393700" or 2/5 of an inch.
Old Sep 8, 2009 | 08:53 PM
Windeed's Avatar
Windeed
My rear rim is 18 x 8.5 and I used the stock 240 tire. Clearance is about 1/8" for me and I have not had any problems. I am sure actual measurements for each brand of tire will be slightly different. Not sure on what affect there would be going to a 3/4" pulley. Common sense tells me a smaller belt might wear faster but I am not a tech. Unless you plan on doing a stage II or stage III motor you might be just fine with the narrow pulley and the 260 tire.
Old Sep 9, 2009 | 04:12 AM
Rocker_Dan's Avatar
Rocker_Dan
Thanks windeed...
Old Sep 9, 2009 | 09:31 AM
El Gato Grande's Avatar
El Gato Grande
I'm also running the 18x8.5 rear wheel and rotor combination (All RC Components). I have the Metzler 260 tire on the back and the clearance between the belt and the tire is about the width of a quarter. If the Avon 250 is a fatter tire, you may have problems. I'll try to post some pictures later.
Old Sep 9, 2009 | 03:39 PM
Rocker_Dan's Avatar
Rocker_Dan
that would be great!!....love to see the a$$ view,
is the 260 noticeably wider than the 240...?
...did you go a 3/4 pulley? as I have been advised this would be neccessary to center the rear properly
your bike looks porno BTW
grazias gato
D
Old Sep 11, 2009 | 10:30 PM
El Gato Grande
Default Here are some pics
I hope they don't cause more confusion as I can barely see what I'm trying to post (jagged edge is belt). I'm running a 1.25" pulley and 1" belt on the 260. The pics are trying to show the clearance is by the hair on my chiny, chin, chin. . .
#1 Rear Tire and Pulley
#2 Close Up of Belt and Tire #1
#3 Close Up of Belt and Tire #2
Old Sep 11, 2009 | 10:37 PM
Rocker_Dan's Avatar
Rocker_Dan
Thanks Gato !!!
Looks it just fits by a bee's dick
I appreciate the trouble
Dan
snatchcat
Mar 13, 2019 04:39 PM
Alain
Softail Parts
Jan 8, 2015 10:23 AM
rkc9999
Sep 27, 2013 03:57 PM
UT-rckr
Feb 16, 2013 07:16 PM
Lockshow
Feb 10, 2013 12:27 AM
