Front Brake Rubbing
Old Sep 23, 2009 | 12:54 PM
centennialfatboy's Avatar
centennialfatboy
Originally Posted by tk353
Originally Posted by FastHarley
Try what I suggest in the post right after this one LINK: https://www.hdforums.com/forum/sport...ange-easy.html
We fix lots of them. I have posted several times on this subject, had several HDF Member down who said it is normal, and also cut quite a bit of new wheel spacers when they were too short and the leg was pulled in. It is not normal when the brake pad rubs, the rotor gets hot or all of that other BS. Do a search, and just fix it by doing it.
Makes perfect sense! Thanks guys!
Old Sep 23, 2009 | 01:25 PM
screamn_eagle's Avatar
screamn_eagle
IT'S NORMAL....IT'S NORMAL.... IT'S NORMAL....(please don't try to pry your pads away, or fix it in any way) because IT'S NORMAL
Old Sep 23, 2009 | 01:51 PM
centennialfatboy
I don't plan on prying against the pads but can definitely see where built up crud would keep the pistons from releasing enough to allow the pads to scrub some. I can't see where cleaning it all up could hurt.
I was in the auto repair industry for 15 years and would see plenty of calipers sludged up and not releasing properly and that was with rubber dust boots.
If I clean it all up and it still does it, no biggie it must be normal and I have nice clean caliper pistons.
If anyone implied prying the pads back would fix it, that would be incorrect because the next time they apply them they're right back where they were and scuffing pads with sandpaper would not be recommended either since you won't be able to make the surface completely flat and will reduce braking effectiveness until the pads wear themselves back flat. Plus the fact that doing so will do little to nothing but reduce the life of the pads.
Old Sep 23, 2009 | 01:52 PM
FastHarley's Avatar
FastHarley
Former Sponsor
I guess when I get my customers bikes in that are rubbing more than allowing the wheel to turn less than 1 rotation when spinning the wheel abnormal? Ya, I get everyone of them to spin between 1 1/2 rotations to 2 rotations on a HD. Abnormal it is.
Brakes
Brembo Brake Maintenance Guide
PDF Download
Twin Cam Brake Maintenance Guide PDF Download
Twin Cam Brake & Control Illustration PDF Download
Old Sep 23, 2009 | 10:07 PM
keeferfish's Avatar
keeferfish
Brakes
Brembo Brake Maintenance Guide PDF Download
At two rotations couldn't it still make noise? I replaced the front and rear caliper with new chrome ones and they still made the exact same noise. Front only - that I coudl tell.
@@@ When the car makes a noise I JUST TURN UP THE RADIO!
Old Sep 23, 2009 | 10:21 PM
tk353's Avatar
tk353
i dont have noise after the front bearings were replaced and i use lyndall pads
to clean my pistons i used brake cleaner. i slide the caliper off the rotor, squeeze the brake lever until the pads came together and sprayed with brake cleaner and then hand pushed the pads apart
Old Sep 24, 2009 | 04:50 AM
hpfatboy's Avatar
hpfatboy
NORMAL noise, DONT SWEAT IT!!!
Harleyforever
Apr 18, 2016 08:52 AM
SE11
Jul 18, 2013 04:19 AM
Ghosteh
May 5, 2011 11:01 AM
3rdgear
Sep 6, 2009 08:22 PM
JerseyDevil
Oct 3, 2008 09:16 PM
