Exhaust options~expertise needed
1) Will they work? Anyone have this setup already or at least have the slip
ons so I can get the diameters?
2) Any ideas on performance numbers with the slip-ons and baffles?
3) Can I put everything on myself without having to worry about
re-calibrating my bike? Do I have to go with a stage one setup for slip-
ons?
4) All together (if I can put them on myself) the cost will be around 650, is it
worth it or should I look for something else?
Thanks in advance.
Edit a little bit on here for ya...
Performance wise you really won't get any gains unless you get a new A/C along with a power commander, sert, TMAX or any other fuel management system like that. Mainly the slip-ons is a good cheap quick way to get rid of that quiet factory sound. Usually people get them with the 1.75 baffles but if you want them louder you can get them in 2.00 or 2.25 baffles...you will loose low end tq the bigger (in inches) your baffles get. Like I said most people here seem to run 1.75 because the sound is much better and you don't lose that much low end tq.
Thanks for the advice. Keep it coming...
Mine went from 63.99 hp to 75.41 hp and 78.16 tq to 87.36 tq. I did rush slip ons and pc lll and big sucker. I had a dynotune done. canned maps are not close if you want smooth responce at any speed or throttle. From the post i have seem i would get another 2 to 3 hp if i changed the entire exhaust.
i use the stock hd heat shields and they fit on the rush
