clearance issues with bigger rear rim?
Old Oct 27, 2009 | 06:32 PM
sledhead140's Avatar
sledhead140
Default clearance issues with bigger rear rim?
has anyone had any issues with a 18" rim compared to the stock 17" ? i have my train lowerd 2 inches and wondering if this would be a problem?
thanks
Old Oct 27, 2009 | 07:01 PM
ScReaMnEagLE22's Avatar
ScReaMnEagLE22
shouldnt have any issues. there are many guys running a 18x5.5, 18x7 also.
Old Oct 27, 2009 | 09:59 PM
mstng5point0's Avatar
mstng5point0
I have an 18x5.5 and the only issue i have is my tire rubbed my license plate bracket cause one fo my friends todl me to try a 200/55/18 avon which is alot taller. Its on a 18x5.5 wheel. I moved the plate up and cut about 3/4 or an inch off the bracket and its fine but it just doesnt fill the fender up the way i want. going to a 200/50/18 metz next. Wish i knew about the 18x7 before tho.
Old Oct 28, 2009 | 08:23 AM
Chazmanian's Avatar
Chazmanian
R.I.P. BROTHER
18" wheel is the hawt setup for a lowered Train or any sloptail for that matter....The issues arise when you stray from the smaller Metz tires and start doing D-Lops and Avons. They are way bigger!!
Run the 18" with a Metz 210 and lower it just right and you will be golden!!
Old Oct 28, 2009 | 08:25 AM
97FXSTSB's Avatar
97FXSTSB
I went from a stock 16 to an 18 and no problem. Overall diameter and width did not change.
Old Oct 28, 2009 | 09:49 AM
ScReaMnEagLE22
what size tire/rim you running up front ?
Old Oct 28, 2009 | 05:04 PM
sledhead140
the main issue i have is with my bike being lowerd 2 inches. my front rim is the stock 21"
Old Oct 28, 2009 | 07:46 PM
mstng5point0
I wish they made a 210 metz for an 18
Old Oct 28, 2009 | 08:22 PM
ScReaMnEagLE22
Why is this an issue? Seems most guys that are running the 18 inch wheel are lowered bikes +2 inches... and also have 21" up front...
Joeynotz
May 19, 2016 04:36 PM
outlaw bagger
Mar 13, 2013 06:45 PM
olongapo1
Aug 30, 2011 11:25 AM
ICIBUY
Dec 27, 2009 05:26 PM
stevepacman
Jan 17, 2009 08:31 AM
Top
© 2026 MH Sub I, LLC dba Internet Brands
Follow Us
