REAR BRAKE LIGHT ON HERITAGE
Old Jul 7, 2006 | 12:58 PM
RCVBYFR's Avatar
RCVBYFR
2nd Gear
Default REAR BRAKE LIGHT ON HERITAGE
HAS ANYONE HAD ISSUES WITH THEIR REAR TAIL LIGHT NOT ILLUMINATING VERY BRIGHT? MY 95' HERIATGE BRAKE LIGHT DOESN'T SEEM TO BE VERY BRIGHT WHEN THE BRAKES ARE APPLIED.
Old Jul 7, 2006 | 01:03 PM
06FLSTCi's Avatar
06FLSTCi
Default RE: REAR BRAKE LIGHT ON HERITAGE
Did you check the voltage? Maybe bad ground?
Old Jul 7, 2006 | 01:44 PM
dert's Avatar
dert
Find the brake light switch and try reversing the wires on connector leads...if not they may be just loose ..The switch is on the right just behind the transmission cover.I have a 92 and mine will vibrate loose every so often ,but after so much trouble shooting,it was reversed leads .( I reinstalled backwards after installing a new switch)
Old Jul 10, 2006 | 12:42 PM
RCVBYFR's Avatar
RCVBYFR
2nd Gear
THANKS FOR THE INFO. I WILL TRY THAT AND LET YOU KNOW IF IT CORRECTS THE PROBLEM
eddy287
Jul 18, 2013 10:07 PM
mballard
Shovelhead
May 19, 2012 05:33 PM
iltbone1
Sep 19, 2011 12:18 PM
Drbukk06
Sep 9, 2011 01:20 PM
Fsellaro
Mar 31, 2010 07:53 PM
