replacing fuel guage
Old Nov 6, 2009 | 10:02 PM
TRI GLIDER's Avatar
TRI GLIDER
4th Gear
Default replacing fuel guage
my problem is that I need to replace the fuel guage on my 2007 Softail Custom, does anyone know:
do you have to remove the tank to reattach the wires to the wiring harness ?
or can you use the existing hole on top of the fuel tank to reach the wiring harness ?
last one, does the wires connecting the fuel gage just plug into the wiring harness ?
I am a novice and thank you for any help at all ....
Old Nov 6, 2009 | 10:18 PM
WVNightrain Rider's Avatar
WVNightrain Rider
It is a real pain but you can get to the conector and unplug it under the tank then remove the pins from the conector and pull them up through the hole in the tank. Just make sure you insert the new wires right so the colors match (black, orange, and yellow).
Old Nov 6, 2009 | 10:20 PM
2kids3pets's Avatar
2kids3pets
CP from another forum
The wiring goes threw a little hole from the top of the tank to the bottom of it.The wires are just in front of the horn and come out the bottom of the tank and connect to a small connection near the frame at the top of the motor mount or near the rocker box cover...LEFT SIDE OF THE BIKE
Old Nov 6, 2009 | 11:26 PM
anubisss's Avatar
anubisss
Simple. Unplug the connector from the fuel gauge under the tank. Plug in the new fuel gauge.
Old Nov 7, 2009 | 06:40 AM
tk353's Avatar
tk353
my 07 has the plug under the tank and the hole is large enough to just pull thru
Old Nov 7, 2009 | 09:00 AM
Man In Black's Avatar
Man In Black
Default Might be the sender.
Are you sure it is the gage and not the sender? My gage on my 2010 Heritage is not accurate and the dealer is replacing the fuel sender in the tank on Monday. And they claim that the fuel gage problem was fixed on the 2010 models. ???
Old Nov 8, 2009 | 07:01 AM
WVNightrain Rider
Now that would be nice.
Chad1200
Jul 30, 2020 02:28 PM
Am4wag
Nov 9, 2014 07:47 PM
akpackfan
EVO
Jun 26, 2012 07:53 PM
06ClassicRider
Aug 3, 2008 05:23 AM
Vikingnomad
Jun 25, 2008 09:38 PM
