Fuel Leak from wire going into tank?
Old Jun 25, 2012 | 10:19 PM
akpackfan's Avatar
akpackfan
Default Fuel Leak from wire going into tank?
I've got a fuel leak coming from the wire bundle that goes up into the fuel tank on the left side, bottom, front of the tank. It's just in front of where the fuel lines thread into the tank. How does this seal in the tank and how do I fix this? Any help is appreciated.
Old Jun 25, 2012 | 10:59 PM
akpackfan's Avatar
akpackfan
Ok, I disconnected the plug under the tank that the two wires that come out of the tank are wired too. It appears one wire is for the fuel pump (no fuel pump noise when turning the switch on) and one wire is for the fuel gauge (no fuel gauge movement when turning the switch on). So now the question is, how does this two-wire bundle seal in the tank and how do you repair this leak? Anyone have any experience with this?
Old Jun 25, 2012 | 11:04 PM
soft 02's Avatar
soft 02
What model and year?
Old Jun 25, 2012 | 11:18 PM
akpackfan's Avatar
akpackfan
Sorry, '97 Road King fuel injected.
Old Jun 25, 2012 | 11:30 PM
soft 02's Avatar
soft 02
Cant find what I'm looking for but if its like others there is a tube that goes all the way through the tank to the gauge on top. Mine had a seam leak under the gauge and I used some gas tank putty to seal it. Look under your gauge to see if it is leaking there.
Old Jun 26, 2012 | 01:36 AM
akpackfan's Avatar
akpackfan
No, it is leaking under the tank where the two-wire bundle goes up into the tank. There is no tube involved, it's two wires that penetrate up into the tank. I have a service manual but I can't find anything that says how the penetration is sealed around the wires.
Old Jun 26, 2012 | 06:45 AM
miacycles's Avatar
miacycles
There is a tube that goes up into the left side tank and exits under the phony left side gas cap/fuel gauge. The power for the fuel pump goes to the panel that is located center top of the tank that also allows you to access the fuel pump. The leak is probably at either the top or bottom of the tube where it is welded to the tank. Gas tank putty will fix it, or you gould use JB Weld. Hope this helps.
John
Old Jun 26, 2012 | 10:58 AM
crawford769's Avatar
crawford769
My brothers was leaking there and we just replaced the gasket under the fuel guage float and it fixed the leak.
Old Jun 26, 2012 | 07:53 PM
akpackfan's Avatar
akpackfan
Wink
Ahhh, I see what you guys are talking about now. I took off the "fake" fuel cap/fuel gauge and saw the plate and wires in there with the gasket underneath. I tightened the torx screws a little and so far no more leak. I'll get the gasket anyway so I have it if I need to replace it. I found a great youtube video of a guy showing how to change it on a 96 softail. Thanks for the help.
OrdO8085
Apr 3, 2022 02:08 PM
brihvac
Nov 6, 2010 09:28 PM
jstar5744
Apr 9, 2008 04:18 PM
Rev00
Oct 30, 2007 02:57 PM
Xenarchi
Dec 9, 2006 07:03 PM
