Front Brake or Rear Brake
Old Jul 11, 2006 | 02:27 PM
Carolina Fatboy's Avatar
Carolina Fatboy
Default Front Brake or Rear Brake
I an a fairly new owner of a 2003 Fatboy. It's been a while since I have ridden so I'm really just getting started again. I've noticed that it just seems natural to me to slow down by downshifting and using the front brake. I rarely of ever use the rear brake. My question is am I doing this wrong or is it really just a matter of preference? The only issue that I can see is that I'll wear out the front brake long before the rear.
Reply with your thoughts and advise please..........[8D]
Old Jul 11, 2006 | 02:35 PM
oldgeezer's Avatar
oldgeezer
Default RE: Front Brake or Rear Brake
No problem really with just using the front brake but I'd get in the habit of using both. Reason being that if you are in the habit and have a situation where you need maximum braking, you'll be already in the mode to use both, which give you maximum braking.
Old Jul 11, 2006 | 02:44 PM
gconklin's Avatar
gconklin
As I was taught, the front brake gives you 75% of your braking power so its better to at least be ontop of that one if you had to choose. But using both evenly is best for maximum braking power, of course. Though, I'm not one to preach that because I gernally only use the front brake while downshifting as well, unless I'm in a turn or believe there could be some slippery surface ahead.
Ride safe!
Old Jul 11, 2006 | 06:33 PM
u_neek24's Avatar
u_neek24
I was taught and have read that the front brake should provide 75% of your stopping power. Yes...Front brake. Many of the "experienced" guys I ride with disagree. They say you'll flip and do an endo. NOT THE CASE. Those riders have picked up a bad habbit and will end up in some sort of a power skid at 60mph by slammin on that back brake. The best way is downshifting if possible (called engine braking) then appling both brakes at the same time with. 75% in front and oh yes...I did the math...25% from the back. This method is taught by MSF, Harley's riders edge course, and every single DMV study guide from every single state of our beloved nation.
ORIGINAL: gconklin
Ride safe!
Old Jul 11, 2006 | 06:37 PM
Carolina Fatboy
I really appreciate the input, seems as though I might change my riding style slightly. This is what I like about this site, good information without the condesending attitude.
Thanks again to those who have replied.
Old Jul 11, 2006 | 06:38 PM
cjmilez's Avatar
cjmilez
Just remember~~> if you are turning or in a curve...DON'T use the front brake..
Old Jul 12, 2006 | 01:10 PM
fxstcguy98's Avatar
fxstcguy98
I use both as stated above 90% of the time. Sometimes I will use only the rear if I need to scrub a little speed, like if some jacka$$ is going slow in front of me or I go into a corner a little hot. That's my way of trying to even pad wear from front to back.
Old Jul 12, 2006 | 04:36 PM
Bluerose
Guest
Posts: n/a
I use both and downshift. Use rear if I just need to knock down some speed a bit especially if I'm in a corner (just a bit of feathering)
Old Jul 13, 2006 | 03:45 PM
sfcmo357's Avatar
sfcmo357
yep----front brake is 75% of stopping power.......but you should use both. At least that's what I was taught by the professionals years ago when riding street bikes.........you should notice that you have to squeeze less on the front brake if you use it in conjuction with the rear brake and downshift also
Grumpaw
Jun 5, 2019 10:53 AM
SGMongoose
2014-2024 Touring Models
15
Nov 27, 2015 06:55 AM
wastedranger
Nov 13, 2014 08:36 AM
"Redwood"
Jun 3, 2012 06:49 PM
msbhvn
Feb 9, 2006 07:53 PM
