Question re D&D Fatcat and Mapping
Not all combo's work so great together....You probably know that though.
211's are unhappy in a stock compression virgin headed motor. They need to be in a high comp motor with some headwork or they will hold you back.
Now you added a pipe that inherently isnt gonna rev out as freely on the top end which is the only place your 211's are working if your motor isnt molestered?
Get it tuned to the 2-1 pipe. When I went from a set of BSS to a 2-1 Rinehart and my bike is tuned with Direct Link it took a good tuner hours to get it just right.
Here is what a high comp 95" with headwork and 211's showing a set of BSS (Blue Line) and a Rinehart 2-1 (Red Line) at 6,000 feet above sea-level. If you are at sea-level or something reasonable and not in the thin air as me you would see about 10% better numbers or 100+Hp/110+Tq on this relatively cheap yet effective and fun to ride build.
If you look at the graph you see the 2-1 simply killing the 2-2 BSS in the midrange or where we typically ride our Harleys. So as it gets up to 5K RPM the BSS reasserts itself and makes a few more ponies.
Without the headwork and compression? These peaky 211's simply will not work as they should and will essentially ride like a 2 stroke dirtbike....Flat, Flat, Flat Peaky, Flat.
Bump the comp on your bike if you havent already via shaving the heads, thinner base gaskets or pistons, have the head porting worked, get it tuned on a dyno by someone who knows what they are doing and you will have a ripper on yer hands.
I was gonna go extreme this winter with a 113 or something crazy but realized that with one hand on the bars (Jockey Shifter) I can hardly hold on as it it is!!
You called it re that SE211. That cam doesn't come alive till you get over 4K rpm, then it's a screamer. I was hoping the Fatcat would add to the low end grunt that was missing. It did that, but it also seems to hold the engine back at high rpm. Right now I'm mostly concerned with the flat spot in the mid range, not so much losing power at the top. The dyno chart when I installed the 211 showed a little dip around 2K but I didn't really notice it. Now, I think the Fatcat makes that dip more noticeable. Overall, I'd like a more consistent throttle response. I'm bringing it back to my mechanic for a dyno tune in the next 2 weeks. He said he should be able to improve things. I don't expect to do any more engine work right now but if I had to do it all over, I probably should have picked a milder cam.
That being said you look lean off idle IMO....Is it pinging or running hotter than usual?
Does your dyno guy have the ability to add the A/F graph on the bottom of his sheets?
Think compression and some headwork....You are sitting on a bike that wants to make 100/110 easy and cheap!
