Check engine light!
Old Jan 4, 2010 | 05:22 PM
tk353's Avatar
tk353
give us a code
Old Jan 4, 2010 | 05:24 PM
schumacher's Avatar
schumacher
a little cut square of electrical tape will fix that
Old Jan 4, 2010 | 07:51 PM
mke125125's Avatar
mke125125
do you work at my dealer? just kidding!
Old Jan 4, 2010 | 08:17 PM
josh_m_0509's Avatar
josh_m_0509
Originally Posted by firecwp
Just because your battery reads in a good range doesn't mean that it is good. If the battery is bad it can still read good, but fail under a load. I am going through the same problem. Take the battery out and take it to someone who can load test it. A load tester is a set of cables hooked up to a heater w/ a volt meter. When the button is squeezed the battery heats up the heater and you can see on the meter the voltage drop. How much it drops and how it recovers proves if the battery is good or not. A low battery does throw out a code and service engine light will come on. Continuously trying to start your bike with a low battery can gauld your starter due to kickback of the flywheel. After you get a new battery the code will still come up as a "history," code. If you plug in your bike you can erase the history so it won't show up anymore unless it is a new one. I'd load test and plug in before I did anything else.
Thanks for the advice, I'll definitely give it a shot!
sixshooter
2014-2024 Touring Models
36
Oct 3, 2015 07:28 AM
Fedoraman
Dec 14, 2013 05:17 PM
bdavis385
Jun 1, 2008 10:24 PM
HDRoach
Apr 18, 2008 04:01 PM
tylerdynaWG
Nov 12, 2006 11:03 PM
