I have the heated gloves from HD, can you just plug a tender into the little pigtail that comes from the battery? If so does the store brands come with the same plug?
Thanks
Tim
Yeah, just plug into the pigtail. Deltran battery tender, HD branded(I think made by Deltran too), both come with the connector in the box. Don't have to worry bout overcharging with battery tenders....computer chip prevents it! Be careful with a trickle charger, though! Can overcharge with one of those! Plug into a tender for as long as you want...whenever you're not riding...battery will last!!!
I just check the voltage on mine at the pig tail about once a week, and if it is down below about 12.4 I plug in the battery tender for a day. That usually brings it back up to well over 13. I guess it would be alright to just leave it on, but this way I do not over charge it and am able to keep track of it better. This is just my winter routine.
I believe that's the advantage of using a 'tender' charger. They do not 'over charge' even if left on for months at a time.
i have one and have had 1 for all my bikes. but, i almost never use it. because, i figured the cost of the electricity multiplied by all winter for several winters might be more expensive than the new battery. plus, my batteries have allway lasted a long time. even in the winter my bike usually doesnt sit for more than a week or two without being ridden.
Enlighten me as to how much money it adds to your electric bill every month. And if it isnt noticeable, i will start plugging mine in.
bought my HD brand one with a gift card about two years ago. I use it anytime the bike is going to sit for more that a week or two. The HD one is the same as the Deltran battery tender. I acutally like the compact size, but then again, I used a gift card. you can get the same tender (w/o HD Label) for like $25. I think it's the battery tender Jr. from Deltran.
+1 I bought a Battery Tender from these people http://www.batterystuff.com/ I called them before buying and asked about the different types of chargers, etc. They said that the tenders were they way to go for reliability and longer battery life. You may pay a few bucks more for a tender, but over the long haul it's worth it. I just hook it up and walk away. It only charges when the battery needs it and then only a trickle. I talked to one of the local bike mechanics and he said that it just about tripled the life of batteries.
don't worry about the cost of electricity.....probably costs the same as running a light bulb.....you will NOT notice a difference in your electric bill at all!!
