battery tender use
Old Jan 8, 2010 | 09:19 AM
rscalzo's Avatar
rscalzo
Best price I've seen for the Battery Tender
http://www.chaparral-racing.com/Chap...7ACD44D9C8B5FC
Old Jan 8, 2010 | 04:39 PM
MercMarauder's Avatar
MercMarauder
Originally Posted by hogowner69
don't worry about the cost of electricity.....probably costs the same as running a light bulb.....you will NOT notice a difference in your electric bill at all!!
I use the tender ALL the time!!!
Much less than running a light bulb. I have measured while mine is plugged in. It uses between 2 and 3 watts while in float mode - less than a night light. I leave my Deltran Battery Tender on the bike all the time it is not out being ridden - winter and all seasons.
Old Jan 8, 2010 | 05:10 PM
CSRflstc's Avatar
CSRflstc
I just picked up a battery tender at WalMart. $20. Temps are getting in the single digits at night and 20's during the day. I went out yesterday at lunch to fire the bike up and ride it back to work (26 degrees), and the battery was too weak to do it. I had to jump it off with the car.
Old Jan 9, 2010 | 12:14 AM
uberhawg's Avatar
uberhawg
These guys have the good Battery Tender by Deltran:
http://www.retrocycle.com/CustomChro...arger_12V.html
If you save $20 on a cheap charger but it kills your battery it is less than useless. Keep your battery topped off all the time and its always ready to go and your battery will last longer. These things won't over charged the battery. And it uses so little electricity its not even close to a concern.
Old Jan 9, 2010 | 09:40 AM
goo's Avatar
goo
Default whut i does is this, thusly
i put it on a timer. the tender is only on 4 hrs a day. more than enough. don't gotta worry about stuffing too many amps into the battery. last year i checked on the bike in the garage and there was amps laying all over the floor. this ain't happened since i started using the timer
Old Jan 9, 2010 | 09:56 AM
Rockyriver's Avatar
Rockyriver
Originally Posted by goo
i put it on a timer. the tender is only on 4 hrs a day. more than enough. don't gotta wory about stuffing too many amps into the battery. last year i checked on the bike in the garage and there was amps laying all over the floor. this ain't happened since i started using the timer
Im going to get a timer also for mine. I had a battery tender on my boat and the acid level would be low in it come spring. I know the tender, trickle charges but day end and day out, I wonder if its over kill.
A timer set to 4 hours a day, would be the ticket. Also I crank my bike and run it at least 2 times a week, I wonder if all the tender is going to do for me is keep my battery a little warmer on cold nights in the garage.
Old Jan 9, 2010 | 11:08 AM
57RebelRocker's Avatar
57RebelRocker
been awhile brother but yeah just plug it in and let it do it's thing
Old Jan 9, 2010 | 11:52 AM
ranger56528's Avatar
ranger56528
Mine stay on all winter(around 5 months) then unpluged when riding weather arives.
Old Jan 9, 2010 | 12:01 PM
blackfatty's Avatar
blackfatty
i have a small charger, but it doesn't have the auto shut-off. i'm going to get the battery tender junior. should i go with 6V or 12V for my harley and 4-wheeler?
Old Jan 9, 2010 | 03:00 PM
frankiefire702's Avatar
frankiefire702
Here's the one I have. Plug it in and forget it. Works great.
http://cgi.ebay.com/ebaymotors/MOTOR...Q5fAccessories
