Soft brakes
Old Jan 8, 2010 | 09:11 PM
RocketRocker's Avatar
RocketRocker
Default Soft brakes
Got my bike back yesterday from getting my clutch adjustment fixed and while they were at it I had them bleed my front brakes cause I didnt think I was getting all the air out. When I was riding it home I noticed that they were still soft...catching about 1/4 into the pull of the brake lever. I called today and the wrench told me that it was due to braided lines, that braided lines were going to give me a softer feel on the brakes? Is this true? Does anyone have any suggestions on how to get the slack out of the front brakes?
Old Jan 8, 2010 | 10:28 PM
78fxs78's Avatar
78fxs78
Braided line flexes a little more, I don't think it should be that much, don't use them myself but I put a braided line on a friends bike last year and they worked and felt the same as the original. If you can get the Master to sit at a level with the wheel turned to the left and maybe loosen it on the bars, open the cover and slowly work the lever, pull tight, let off, repeat several time and see if you can get some air bubbles to work up and out.
Old Jan 8, 2010 | 10:38 PM
Notgrownup's Avatar
Notgrownup
Clean you Caliper pistons... it may make a diference...It did for me.
m i k e's Avatar
m i k e
thats bull i bled mine there rock solid mon
Old Jan 8, 2010 | 10:40 PM
m i k e's Avatar
m i k e
lets see some more pics of yo new pimp ride dude !!!!
Old Jan 8, 2010 | 11:09 PM
RocketRocker
The bars (brake resovoir) sit at almost 45 degrees but I guess I cant try and mess with it...I know the caliper pistons are clean. I will post up some more pics after I clean her up maybe tomorrow...snowed today about 1.5"
Old Jan 8, 2010 | 11:56 PM
Heritage632's Avatar
Heritage632
I have all Barnetts braided lines and didn't notice any difference when I put them on vs stock. FWIW
Steve
Old Jan 10, 2010 | 09:51 PM
cgoing's Avatar
cgoing
Default braided lines
My last bike had braided lines and they weren't any softer than the stock ones.
Old Jan 10, 2010 | 10:14 PM
FLTRI17's Avatar
FLTRI17
Default Flexing braided lines?
A little braided line history:
Braided lines were invented to reduce/eliminate flex over OEM rubber lines. This is why virtually all race vehicles use braided lines. Stainless braid helps to retain conformity of the liner tube (usually semi-rigid) inside.
My only advice is for you to go to the service or store manager and tell him what this mental midget said to you. If the manager backs him up, take your bike to another shop and warn all your friends of this incompetence.
Hoping this is taken in the spirit in which it was intended,
Bob
PS - Here's a bit of info:
http://autospeed.com/cms/title_Braid...9/article.html
Old Jan 10, 2010 | 10:52 PM
RKKY's Avatar
RKKY
Braided lines on my FXD and 1125CR, stock lines on my FLHX. Bled them all myself, no noticable difference between them.
CamelRider
Sep 27, 2018 03:39 PM
nashvegasmatt
Mar 8, 2015 02:37 PM
cavalier2000
Dec 24, 2010 08:47 PM
sddyna
Oct 19, 2009 08:28 AM
Road_Clam
Apr 23, 2007 09:49 AM
