Turn Signal Relocation
Old Jan 11, 2010 | 07:19 PM
TedMan's Avatar
TedMan
Default Turn Signal Relocation
For you Crossbones/Springer owners, I've got the brackets to relocate my signals down to the rigid fork. Just wanted to know if there are any tips/advice, or is it really as straightforward as unscrewing the bolts, attaching the signals to the bracket, and then the bracket to the fork. Thanks for any feedback.
TedMan
Old Jan 11, 2010 | 07:21 PM
glideridemike's Avatar
glideridemike
Just make sure no moving parts will hit it.................under the most extreme action and greatest amount of movement.
Old Jan 11, 2010 | 08:02 PM
skipper469's Avatar
skipper469
Yeah, it's that easy. You will have extra cable because of the shorter distance to the forks than the handle bars. You can either zip tie the loose cable up somewhere, or if your good at wrenching, I've heard of guys loosening up their gas tank, and pulling the excess cable back towards the battery. I did the first route since I suck with a wrench. There are also the four plastic clips that hold your cables to the bars. If you can manage to get them out without breaking them, good for you. I just pulled the little bastards out by force. Four new clips at the dealer can't be more than a dollar or two. Anyways... It's very simple.
Old Jan 12, 2010 | 07:08 AM
glideridemike
For the cleanest looking job, mount the signals where you have determined they work best, then start at the signal and run the wires back toward the frame/tank area. Not too tight, but not loose and flopping. Neat and orderly and push any excess wire back into the frame where it comes out, doing so carefully so you don't nick any wires.
Old Jan 12, 2010 | 12:18 PM
TedMan's Avatar
TedMan
Great, thanks a lot for the feedback Glider and Skipper.
TedMan
Old Jan 12, 2010 | 12:22 PM
skipper469's Avatar
skipper469
No problem man. Anytime!
Old Jan 12, 2010 | 01:43 PM
glideridemike
No problemo Ted. When you're done lets see some pics of that badboy.....
Old Feb 1, 2010 | 08:55 AM
Jholbein's Avatar
Jholbein
6th Gear
Hi TedMan, want to do the same relocation of the front turning signal on my X-Bones, was just woundering where you found the brackets. So far I only found the one which mount to the round tubes, Thanks for the help
MacKo2000
Electrical/Lighting/Alarm
28
Sep 13, 2018 09:00 AM
Elwaupo
May 3, 2017 11:45 PM
CRZYLGZZ
May 17, 2010 05:24 AM
stagolee
Mar 16, 2009 05:25 PM
Convert
May 22, 2006 01:05 PM
