Pipe install help - 09 FatBoy
Old Jan 20, 2010 | 06:41 PM
FrankT's Avatar
FrankT
Default Pipe install help - 09 FatBoy
Hi Guys,
I'm trying to install V&H BSS pipes on my 09 Fatboy but I am having trouble getting the nuts off of the rear cylinder studs, especially the bottom one closest to the oil tank. Is there any tricks to getting these off so I can remove the factory pipes? Do I first need to take the heat shields off or even remove the oil tank? Also, it does not look like you can get a socket on the botton nut. I guess I need to use an open end wrench? What about putting the new one's on? How can I tork them if I can't use a socket? Is it that critical to tork them or should I just get them snug and re-check in 100 miles? Any advise or some quick step by steps instructions would be helpful, since I have never done this before. I bought used pipes off of ebay so they are already put together. Not sure if I am going to have to take them apart to install them. I would really love to do this myself instead of paying the "stealer", but I am not feeling to confident. Thanks.
Old Jan 20, 2010 | 07:08 PM
DaveFLSTFB's Avatar
DaveFLSTFB
Try a 1/4" drive socket and flex extension or universal. They're not very tight and the small size fits in without removing heat shields. There is a specific way to torque those bolts. I will quote a 2007 Service manual
Install upper nut and tighten finger tight.
Install lower nut and tighten to 9-18 in-lbs
Tighten upper nut to 100-120 in-lbs
Tighten lower nut to 100-120 in-lbs
Dave
Old Jan 20, 2010 | 07:24 PM
snip0721's Avatar
snip0721
yep. daveflstfb has it right. i'll add this.....dont even try to use a 3/8 drive socket. wont fit the flange nut correct. end up screwing up the nut. proper 1/4 drive set-up is the only way to go. cheap walmart set will work just fine. steve
Old Jan 21, 2010 | 08:32 AM
VTwin-Goodies's Avatar
VTwin-Goodies
Former Sponsor
As far as torques is concerned, snug them up good, and check in a few days and snug up again, or...take of the heat shields and get the torque wrench on there. But this has never been necessary in my case.
Old Jan 21, 2010 | 08:57 AM
tk353's Avatar
tk353
just a side note sears has a nice 1/4 drive set that i take on trips and works well for little things like that. it was $10 after thanks giving sale. I have the ase and metric
Tw4481
Aug 4, 2018 09:29 AM
BiggestDawg
Exhaust System Topics
13
May 12, 2009 09:58 PM
Astro
Oct 16, 2007 11:21 AM
anubisss
Aug 26, 2006 09:15 PM
tl vette
May 2, 2005 11:15 PM
