In order to mount a Harley oil pressure gauge on the rocker box, I had to remove the seat to raise the tank to get the bolts out of the rockerbox.
Putting the seat back on proved slightly ill-fitting, as the rear spring screw behind the passenger seat would barely line up.
This would have been no problem if they'd had the sense to use ALLENS instead of the eternally slip-prone and uncontrollable straight slotted screws to mount the seat.
So, despite knowing there were allready some scratches around it from the previous owner, and knowing I had a giant flathead screwdriver in my hand, I STILL slipped off the dang thing and put a 3" scratch in my back fender.
I feel like a mad klutz. Dammitboy.
