Fat Boy tie down
Old Jan 26, 2010 | 07:27 AM
In Memoriam Citoriplus's Avatar
May our Moderator Rest in Peace
No matter where or how you attach the tie downs you need to make sure that it can't get any slack in the straps.
So if you tie it down to anything that moves, handlebars, sissy bar or whatever make sure that the frame is secure by putting something like a block of wood under the frame. That way if the truck or trailer hits a bump the bikes suspension can't compress and put slack in the straps.
Any slack at all gives the mass of the bike a running start at trying to snap the straps, or let the bike move sideways while its 'loose'.
You also need to remember that if you do use a block under it that your dealing with a Softail and you have to make allowances for the shocks by cutting out extra room in the middle to clear them. Failure to do so will mean that the entire weight of the bike plus the straps pulling, and any bumps, are going to be putting a side load on them they were never designed to handle.
Good Luck and ride safe
Flashovr89
Mar 14, 2017 09:07 AM
Mike Willmont
Feb 23, 2012 08:59 PM
azfathog17
May 3, 2009 04:37 AM
J_DORSETT
Jan 4, 2009 12:00 AM
sharkey
Jun 5, 2007 04:02 AM
