HD Primary Tensioner Shoe
Old Jan 28, 2010 | 09:24 AM
Bearsoftail's Avatar
Bearsoftail
Default HD Primary Tensioner Shoe
Hey everyone, I have a 03 Softail with 25000 miles on her and I'm about to do the typical service again and have a simple question. Has anyone replaced the tensions shoe through the inspection cover? I'm trying to decide whether to do it or pull the whole primary cover and put a auto adjusting tensioner on it. Any help is appreciated.
Old Jan 28, 2010 | 09:31 AM
xxxflhrci's Avatar
xxxflhrci
Pull the cover. At 25k, I doubt if yours is worn out. 77k on mine and it still looks great.
Old Jan 28, 2010 | 09:39 AM
Bearsoftail
Default Shoe
At 20000 I could see wear. But I am just not sure what it looks like when it needs to be replaced. At there any specs? I don't find anything in the Repair Manual.
Old Jan 28, 2010 | 10:00 AM
luvtoride's Avatar
luvtoride
There's a article in this months Hot Bike mag about cam tensioner shoes. Its called "Old Bike Fresh Heart". The guy went 60,000 miles without looking at them and they were metal to metal and bits of plastic were now circulating around internal parts and oil passages. Cost him a new lower end. The article says The motor co. recommends they should be inspected every 20,000 and replaced if wear exceeds 0.080-0.090. (about half the shoes thickness. they've seen them go bad at 20,000 and go as far as 45,000.
JP
Old Jan 28, 2010 | 10:05 AM
Bearsoftail
Hey luvtoride and xxxflhrci, thanks for the info. I’m pulling the covers off tomorrow and I will check it out. I’m pretty sure the wear isn’t that bad so with luck I’ll just be changing fluids, adjusting the primary, and gettin back on the street.
Old Jan 28, 2010 | 10:08 AM
VTwin-Goodies's Avatar
VTwin-Goodies
Former Sponsor
Replaced my primary tensioner at 45k. Only had a little bit of wear but I did have to pull the primary cover. I used the newer Harley auto tensioner.
Old Jan 28, 2010 | 10:09 AM
IronAss's Avatar
IronAss
I put an automatic on mine not too long ago and it seems to run a little tight. Made quite a bit of noise initially but has gottin quieter as the shoe wears in. I saw an article someplace that said someone makes a hydraulic one that doesn't run tight. I'd rather be tight than loose but just right would be better.
Old Jan 28, 2010 | 10:12 AM
FastHoss's Avatar
FastHoss
Just pull the inspection cover off when you check adjustment on the chain.25,000 is nothing for the shoe in there,it will show a little wear. That's why I don't like the new setup that you can't look in there to see what is going on without pulling the whole cover.
Old Jan 28, 2010 | 10:39 AM
Bearsoftail
Yeah the auto tensioner seems like the way to go. So I will most likely upgrade when I have to replace it. Everyone I know who has added it has had good results. I will let y'all know what I find when I open it up tomorrow. Thanks again for all the help!
Old Jan 28, 2010 | 11:26 AM
XARAN's Avatar
XARAN
I still have stock tensioners in my bike at about 40,000 will be changing to the auto set up when I replace
