Lowering Crossbones
Old Feb 10, 2010 | 01:48 PM
HDUK's Avatar
HDUK
Originally Posted by brettnbama
Tried a search a while back, but got a lot of weird info. What ways can one go about lowering the CrossBones' rear? I know it is already lower than stock softails. Will the lowering "kits" like the bolts and what not still work? What all methods have you guys used?
I had my 2008 xbones lowered before I picked it up new I told them to use white bros lowering kit as they only seemed to be the ones who supplied them at the time for the 2008 I had put 2" seat springs on it as well and have only every ridden it that way so I can't compare it to a standard bike, but the bike has always been comfy the seat does bottom out on bad bumps but I don't mind and any way the bones looks so much better lowered just go for it dude
Old Mar 17, 2010 | 02:14 AM
chuckb16's Avatar
chuckb16
I have a 2009 Crossbones. Rode it for 3 months/3000miles and then lowered it 2" with Progressive Suspension lowering kit. I didn't see any difference in the ride, except when riding 2up. I have some 2" springs coming in the mail next week. We'll see if that makes a difference.
Hardest part was making a home made shock press to swap out the rod from the stock shocks.
Old Mar 17, 2010 | 05:17 AM
TedMan's Avatar
TedMan
I used the Burnout Cycles lowering kit for the rear on mine. I actually think it handles better than before. It is lowered 2 inches. The install is supposed to be plug and play, but the clearance on one of the shocks is not quite enough, so rubber mallot and some gentle taps to get it into place. If you're new to this, have your dealer or a good Indy put them on for you. You can find them in JP Cycles catalog. My bones is up on a lift in storage now, but I will post pix when I can. Good luck.
TedMan
Old Mar 17, 2010 | 06:20 AM
jisham's Avatar
jisham
I used the Burnout kit (installed by an indy)...looks great but the ride is definitely stiffer. I don't mind it all though.
mshred
Apr 23, 2018 07:04 AM
moomba
Nov 11, 2012 08:31 AM
fester1
Mar 19, 2011 10:47 AM
fester1
Mar 14, 2011 01:19 PM
Sash302
Jun 11, 2009 05:17 PM
