Lowering Bolt Question
Old Feb 21, 2010 | 10:46 AM
sBender's Avatar
sBender
Default Lowering Bolt Question
So, I need to drop my *** end and I don't have the coin for air or even for the 422s right now. I was thinking about getting a set of the $20 bolts but have seen a couple of the progressive kits for $100.
So, I might be able to swing the $100 if it's a substantial improvement in ride. If not, I'd rather just go with the $20 bolts.
But I stumbled across a discontinued kit for progressives that aren't chrome but are advertised for 2000 - 2006. Now, I thought the rear shocks were the same from 2000+. Am I wrong? Do you think this kit will fit? For $20 I'm inclined to try it unless someone tells me for sure they aint gonna work.
Anyone have any insight?
Old Feb 21, 2010 | 10:47 AM
sBender's Avatar
sBender
Oh, my bike is a 2009 FXSTB.
Old Feb 21, 2010 | 10:56 AM
murlsquirl's Avatar
murlsquirl
Get the burnout cycles kit from JP cycles. I know a couple guys that run it and are happy. It is adjustable and you don't have to disassemble the shocks. That is what I am going with soon ($70).
Old Feb 21, 2010 | 12:20 PM
Carmell RKC's Avatar
Carmell RKC
If you are going to buy the lowering bolts, just buy the $ 20 ones off of Ebay, they are basically the same thing as the $ 100 bolts from HD. I have 9K miles on the el cheapo ones from Ebay with no problems.
Old Feb 21, 2010 | 12:31 PM
mke125125's Avatar
mke125125
+1. this is the kit that I used and Im very happy with it.I dont have a press and the tools to disasemble the stock shocks or I might have just used the bolts. the burnout kit doesnt require any shock disasembly and its fully adjustable for the height that you want.
Old Feb 21, 2010 | 01:02 PM
BLKnCHRME09Deluxe's Avatar
BLKnCHRME09Deluxe
Agreed...just tighten them up and ur ride will be ok. $20.00 sounds alot better than $100.00 for the same thing.
2000' - later... are the same.
Old Feb 21, 2010 | 01:08 PM
ElSupremo's Avatar
ElSupremo
If you can swing $110, these are same brand I'm running (mine aren't the narrow ones). They're adjustable, and after 1 year+ I've had no complaints.
http://cgi.ebay.com/ebaymotors/ULTIM...item3a56988437
Old Feb 21, 2010 | 01:31 PM
sBender's Avatar
sBender
These are the progressives I was talking about. Has anyone used these?
I think I read someplace that they have a preload which softens the ride a little versus just extending the shock which, from what I understand, stiffens up the rear end. You can find these on ebay for $100. I just happen to have found a set for $20 (but not chrome - which I don't care about) but it states that they are 2000 - 2006.
http://www.jpcycles.com/product/701-...paign=products
Old Feb 21, 2010 | 01:32 PM
sBender's Avatar
sBender
Thanks, ElSupremo. I'll deffinately keep those in mind. Have you done any two up riding with those or just solo?
Old Feb 21, 2010 | 01:36 PM
ElSupremo's Avatar
ElSupremo
I've only done solo, but they should work just as well for 2-up. You can raise or lower with them, and adjust preload for solo or w/passenger.
