What heck is this?
Old Mar 7, 2010 | 04:04 PM
Keithhu's Avatar
Keithhu
Default What heck is this?
There's a wire hanging, with a capped off receptacle at the end, with a black screw attached.
Its behind the air cleaner cover.
Old Mar 7, 2010 | 04:06 PM
anubisss's Avatar
anubisss
For European models.
Old Mar 7, 2010 | 04:09 PM
Keithhu's Avatar
Keithhu
So its supposed to just be hanging back there? Flappin' around like that?
Sheesh, Europe is like a whole other country.
DR. V-TWIN's Avatar
DR. V-TWIN
Former Sponsor
Zip tie it back out of the way.
Old Mar 7, 2010 | 04:24 PM
rbabos's Avatar
rbabos
It's for an active intake control not used in NA models. There is another unused plug beneath the trans for the active exhaust. It's tied off but it seems the factory never ties the intake one off.
Ron
Old Mar 8, 2010 | 07:30 AM
tk353's Avatar
tk353
my Arlen Ness backplate has a place to hold it. its called the "what is this for " connection
Old Mar 8, 2010 | 07:58 AM
Sandcrab's Avatar
Sandcrab
Default Does it look like this
It's hard to really see the connector. does it look like this?
Old Mar 8, 2010 | 08:44 AM
Keithhu's Avatar
Keithhu
That looks like a battery tender pigtail. I have one of those, its definitely not that.
Old Mar 8, 2010 | 08:51 AM
BLACK BAGGER's Avatar
BLACK BAGGER
My god if it works don't fix it lol. ON my RK it's an aux plug in port it's in the manual i guess for heated stuff i don't own.
Old Mar 8, 2010 | 09:51 AM
cryan9's Avatar
cryan9
That use to plug into the factory air breather that was removed when you upgraded to the Stage 1 filter, now the plug is not used and is usually secured somewhere. I glued mine to the flat spot under the tank and between the cylinders behind the air cleaner backing plate.
