just oreder 422s
Old Mar 17, 2010 | 08:13 PM
Sash302's Avatar
Sash302
Originally Posted by tlb
thanks dude, so first the swing arm bolt......should I replace the shocks one on the time? pool one out ,than put the new one in, than do the other one.....right?
Old Mar 17, 2010 | 08:14 PM
m i k e's Avatar
m i k e
sorry to chime in here does 1 long bolt go through both shocks?
Old Mar 17, 2010 | 08:15 PM
m i k e's Avatar
m i k e
love this forum
Old Mar 17, 2010 | 08:20 PM
Sash302's Avatar
Sash302
I don't believe so one for each side...
Old Mar 17, 2010 | 08:28 PM
BLKnCHRME09Deluxe's Avatar
BLKnCHRME09Deluxe
Nope take them both out at the same time. Because your stock shocks will be shorter than the lowering shocks. You cant fit a longer shock into a shorter space.
Old Mar 17, 2010 | 08:33 PM
BLKnCHRME09Deluxe
2 in the rear and 2 up front....i did the fronts first because they were so easy to take off....then to crack the rears(they were fk'n tight!) i used a wrench and a rubber mallet...bingo! Loose!
Old Mar 17, 2010 | 08:35 PM
Sash302's Avatar
Sash302
O.K cool, support the wheel with the floor jake and adjust as needed to fit the new ones in....
Old Mar 17, 2010 | 08:36 PM
m i k e's Avatar
m i k e
hmm i just looked mine looked like just 1
i also have a rocker shouldn't be different eh?
Old Mar 17, 2010 | 09:07 PM
tlb's Avatar
tlb
I was wrong one for each side
REMOVAL
1.
Using a suitable lift . support motorcycle under frame until
rear tire is slightly off the ground.
2.
See Figure 2- 118. Remove boll and washer (1) attaching
shock to rear fork.
NOTE
Snap-on adapter. Part No. SRES24. is necessary to gain
access to shock bolt.
3. Remove flange locknut (5) and washer with grommet (4)
at front of shock .
INSTALLATION
1. See Figure 2-118 . Place washer with grommet (4) inside
frame. Install bush ing (3) over stud end of shock. Insert
stud end through keyed frame tab and loosely install the
flange locknut (5).
2. Coat shoulder of boll (1) with LOCTITE ANTI-SEIZE and
threads of boll with LOCTITE THREADLOCKER 243
(blue) . Insert bolt and washer (1) through shock end.
Pivot shock absorber to align bolt with hole in rear fork .
CAUTION
Softail shock absorber bolt torquing procedure requires
the use of a SNAP-ON-ADAPTER, Part No. SRES24.
Since the adapter lengthens the torque wrench, torque
must be computed with aTORQUE COMPUTER, Snap-On
Part No. SS-306G.
3.
Tighten rear shock hardware.
a. Tighten bolt and washer (1) at rear of shock to 121136
ft-Ibs (164 .0-184.4 Nm).
b. Tig hten the flange locknut (5) to 32-39 ft-Ibs (43.452.9
Nm).
4. Adjust both shock absorbers equally. See 1.16 SUSPENSION
ADJU STMENTS.
Old Mar 17, 2010 | 09:12 PM
BLKnCHRME09Deluxe
Strange...mine has 2 in the rear ...one for each shock. with threads into the swingarm.
Have you ever taken out your shocks to see for sure? even in your diagram it shows one rear bolt per shock.
And one per side up front.
