In my mind this is the way it shoulda come from MOCO
That looks 100,000% better that stock. When I first saw a rocker with the goofy passenger seat stuck up in the air, I pointed and laughed out loud in the dealership. The rocker has more potential than any bike Harley makes, but the MOCO does not understand the DETAILS are what make it. I guess that just makes the aftermarket happy...OR at this point is Harley in bed with the aftermarket...and intentionally puts stuff on the bike that you will have to change.
I actually liked the stock Rocker dash.. The coil/ign was another thing though.. I'd had the key ejected and stuck between the primary and eng at 2 am one too many times.. lol
Alain.. Don't be afraid.. It's very straight forward.. Removing the gas tank is prolly the hardest thing.. You will need to have a die-grinder and some good bits to modify the stock coil mount and you'll need to be able to fab a mount bracket for the coil.. The rest is all in the service manual.. I'll give HD props for a simple to read wiring schematic..
Now that is an awesome mod... Maybe someone could look up the connector numbers and build a connector kit? that way its pretty much just plug and play. Ill go threw the thread and get the list of parts, and try to find some numbers. Later I will pick your brains for the wiring changes, and see if I cant do them in a small Swap Harness.
Thanks for the great Idea!! Mind if I post this over at FXCW.Org??
