shift clunk? ? ?
Old Mar 24, 2010 | 11:05 PM
Greasemonkey1's Avatar
Greasemonkey1
Default shift clunk? ? ?
i have noticed that after my handlebar swap, it seems that when i pull the clutch in and let it out, i can feel it through my feet on the left side, and it makes a loud clunk when i shift gears, the bike is still under warranty, but would like to hear from you guys first, thanx
Old Mar 24, 2010 | 11:14 PM
DR. V-TWIN's Avatar
DR. V-TWIN
Former Sponsor
Try adjusting the clutch. I'd adjust on the cable first. If that doesn't do it bust open the derby cover and give it a full adjustment, or since you are under warranty take it to the dealer.
magnum629c's Avatar
magnum629c
adj the clutch ... try that first
Old Mar 25, 2010 | 12:13 AM
RocketRocker's Avatar
RocketRocker
If its under warranty dont even waste your time....take it in they owe it to you.
Old Mar 25, 2010 | 12:25 AM
kiwideuce's Avatar
kiwideuce
yip! sounds like clutch adjustment,probably just cable adjustment because you put on new bars and switch housing, cable would of been backed off,and not adjusted back up properly!
Old Mar 25, 2010 | 04:55 AM
Blk and Chrome's Avatar
Blk and Chrome
If you did the bars yourself then just adjust the clutch, if the dealer did take it back and have them do it. If you did the swap they will charge you, not the bikes fault
Old Mar 25, 2010 | 07:44 AM
Greasemonkey1
thanks guys, i had the dealer do the bars during winter when they were doin everything half off, so i'll take it back to them
Old Mar 25, 2010 | 08:08 AM
mke125125's Avatar
mke125125
man you can adjust your clutch in less than 10min. I wouldnt hassle with the dealer unless that didnt fix the issue.
Oldskewl
Milwaukee Eight (M8)
50
Apr 26, 2018 02:59 PM
TroutBum
Nov 19, 2017 09:08 PM
mikeman54
Oct 13, 2015 07:58 PM
EdandGrace
Aug 13, 2013 11:22 AM
jjohnson77536
May 11, 2011 06:46 AM
