Combination Digital Speedometer/Analog Tachometer
Old Mar 26, 2010 | 01:40 PM
dwebber's Avatar
dwebber
Default Combination Digital Speedometer/Analog Tachometer
Has anyone installed the new speed/tach part #74717-10? I was wondering if it saves your mileage or if you have to have it done at the dealer.
Old Mar 26, 2010 | 02:05 PM
Mr. Wizard's Avatar
Mr. Wizard
You have to get your dealer to have HD set the mileage on the speedo. I also know this speedo combination has two power sources and in the 2010 ConV you must pull the assy fuse to flash the ECM.
Besides that, great toy!
Old Mar 26, 2010 | 03:25 PM
chrisr99's Avatar
chrisr99
I just ordered one from Zanotti and they are setting the mileage.
I Have heard this is plug and play so hopefully that is the case!
Anyone have one installed already? Wanted to make sure it kept all other functionality. Miles to empty, clock etc.
Old Mar 27, 2010 | 12:17 PM
Mathis's Avatar
Mathis
I plan to put one on my 2010 Heritage. I wonder why it's $200 cheaper than the analog speedo/tach? I'd think digital would be more expensive.
Old Mar 27, 2010 | 12:36 PM
dwebber's Avatar
dwebber
[quote=Mathis;6471263]I plan to put one on my 2010 Heritage. I wonder why it's $200 cheaper than the analog speedo/tach? I'd think digital would be more expensive.
Yea same here, I was wondering the same thing. I believe this one looks better with the console. I also wonder how the display will show up in the daylight.
Old Mar 27, 2010 | 12:48 PM
Mathis's Avatar
Mathis
I can read my current odometer and clock good during the day, so I assume this will be even easier, considering it's got bigger numbers.
Old Mar 27, 2010 | 01:02 PM
Mr. Wizard's Avatar
Mr. Wizard
The digital display is very high quality and can be seen at any angle and light. The RPM dial has a red led attached so it too can be spotted while riding.
Old Mar 27, 2010 | 01:19 PM
dwebber's Avatar
dwebber
I was looking for this for my 2009 Softail custom, the ad on the H-D website said it was a a plug and go. Do I still need two power sources?
Old Mar 27, 2010 | 01:31 PM
Mr. Wizard's Avatar
Mr. Wizard
If HD says it will work for your model year, go with that. Both power sources should be available.
If you use a SERT, SEST or TTS you will need to pull the ASSY fuse to flash the ECM. This digital circuitry will continue to call for a fuel level and will not leave the ECM alone so the J1860 VCI can attach to flash.
Old Mar 27, 2010 | 02:42 PM
jslamerman's Avatar
jslamerman
I was wanting to purchase this for my 2007 (plan to do so even though), couldnt figure out why my softail wasnt listed as an application, it still plugs in, just has the added feature of fuel/mileage remaining...........we will see I guess. Dealer and I went through as much wiring as we could think of, and examined plugs.......SHOULD work.......(famous last words)
