Combination Digital Speedometer/Analog Tachometer
Old Sep 6, 2010 | 09:30 AM
  #41
Softy 103's Avatar
Softy 103
Sorry forgot to tell you I have a sert
Old Sep 6, 2010 | 09:39 AM
  #42
Mr. Wizard's Avatar
Mr. Wizard
Originally Posted by Softy 103
So you pull the assy fuse while you are doing the flash? then put it back when you are done.
Yup, that's right. You don't have to pull the fuse when doing data runs, only to flash the ECM then put the fuse back in.
There are other digital gauges that do the same thing to the ECM.
See page 3 of the latest tech bulletin in the TTS download/updates.
Old Sep 6, 2010 | 09:54 AM
  #43
Softy 103's Avatar
Softy 103
Thanks a bunch , Jeez I love this forum
Old Mar 4, 2011 | 12:07 AM
  #44
GUITARSLINGER67's Avatar
GUITARSLINGER67
Stage I
Default 74717-10 digital speedo/tach
does anyone know if this unit ( 74717-10)will fit in the low profile dash board?.i'm sure it would fit diameter wise but i am not sure of the depth..maybe those of you who installed it would have noticed if it's deeper than the stock speedo?..i have a 2008 fatboy
Old May 17, 2011 | 04:03 AM
  #45
Micah's Avatar
Micah
5th Gear
Anyone know if this will work on an 06 injected standard? Thanks
Old May 17, 2011 | 06:09 PM
  #46
dansax's Avatar
dansax
I ditched the gas gauge on my 2010 Lo. I put on two custom fuel caps. I heard that you need a working gas gauge for the new combo unit to show fuel level. Is that correct?
Old May 17, 2011 | 06:45 PM
  #47
Keithhu's Avatar
Keithhu
Thats been my experience, yes. Is yours working without the stock fuel gauge?
Dealer customer service tech at HD says so as well.
Old May 18, 2011 | 03:45 PM
  #48
dansax's Avatar
dansax
I haven't bought it yet. I was trying to see if that was true. Seems odd that you need a gas gauge to send info to another gauge. Maybe I can buy a small gauge to dump in the cup holder and put my cap over it. I'll have to look into that.
alcotune
Feb 6, 2015 03:58 PM
camden
Aug 19, 2014 11:27 AM
tlsmith22
Jun 11, 2012 08:00 PM
cmosentine
Aug 3, 2011 04:15 PM
mopar
Mar 30, 2010 09:58 AM
