fuel light question
Old Mar 26, 2010 | 02:56 PM
t0mmy91's Avatar
t0mmy91
Default fuel light question
good afternoon all, i have a 2006 fuel injected nightrain. fxstbi. this is my first fuel injected bike. i bought it used so i dont have the owners manual. i have the service manual, but i cant find any info on the fuel light. since this bike doesnt have reserve, i assume the fuel light comes on at some point when the fuel gets low. does anyone know at what fuel level (gallons) it comes on or what range of riding i have left once it does? thanks!!!
Old Mar 26, 2010 | 03:13 PM
doghair's Avatar
doghair
In theory it should go off when you have about 1 gallon left.
Old Mar 26, 2010 | 03:26 PM
magforce's Avatar
magforce
do you mean that it should come on when you have one gallon left, sometimes mine comes on and i still have a have a tank.
Old Mar 26, 2010 | 03:53 PM
doghair's Avatar
doghair
Sorry, I reversed that didn't I. It should illuminate at one gallon. Again, in theory. Mine is pretty accurate but I have read quite a spread of what other people see.
Personally I use the odometer primarily and use the fuel gauge and low gas light as second opinions.
Old Mar 26, 2010 | 04:00 PM
ejohnson1's Avatar
ejohnson1
Mine also has a miles left to empty option in the odometer display.
Does adding a Power Commander or other piggy backed fuel management affect the accuracy of gas mileage based features or readouts? I hadn't really thought of it until I read his post.
Old Mar 27, 2010 | 08:50 PM
In Memoriam Citoriplus's Avatar
May our Moderator Rest in Peace
Use the odometer, the idiot light really is an idiot light on Harley's and the gauge isn't a hell of a lot better.
Most are so inaccurate hardly anyone trusts them to do more than look nice.
Adding a PC or any other fuel management add on system WILL screw up the 'miles to empty' feature, that is if it ever worked right in the first place.
The reason is easy to understand when you remember that the PC modifies the injector output, lengthening it in most cases. So the ECM is basing its mileage estimates on how much fuel it 'thinks' its putting into the engine. But with the PC making the injectors put in a little more every time. The gas tank IS going to go dry sometime before the ECM thinks it should.
A reasonable rule of thumb would be to refull the tank every 100 miles (it easier to calculate mileage with a 100 mile base) until your sure you understand how much mileage your really getting then adjust your refill mileage mark from there.
Ride Safe.
Old Mar 28, 2010 | 01:27 AM
Bowtieman31's Avatar
Bowtieman31
The light on my 07 Heritage goes on when I have .9 gallon left in the tank. As mentioned above, I use the odometer and fill up at 150 miles.
Old Mar 28, 2010 | 06:30 AM
t0mmy91's Avatar
t0mmy91
ok, thankyou very much everyone!
wheeler095
Apr 13, 2013 01:46 PM
Cupcake1973
Sep 7, 2011 03:58 AM
logdon17
Jul 27, 2009 09:53 PM
KeithB
Sep 21, 2006 12:11 AM
igniter
Feb 20, 2005 08:36 AM
