Installing Tach on Deuce
Old Aug 7, 2006 | 10:55 AM
Jezcruzen's Avatar
Jezcruzen
Default Installing Tach on Deuce
I recently purchased a tach "kit". I usually can install accessories as long as good directions are included. I'm having trouble dicephering the instructions for this tach, however.
Have any of you installed one of these tach kits? How did you run the wiring? (I'm not sure whether to run it underneath the gas tank or the console.) On mine, I have to make three connections - the 'ground' connection located beneath the seat on the frame, the fuse box, and to some misteryous location on the speedometer.
Any guidence would be be appreciated.
Old Aug 7, 2006 | 01:44 PM
06DEUCE's Avatar
06DEUCE
Default RE: Installing Tach on Deuce
i didn't install mine hd did, but i have looked it over. mine the wires run under the gas tank, and the one for the speedo i think runs up the front of the tank with the factory harness.
[IMG]local://upfiles/4583/18E7D36BB1914EA0A4A3BBA065482E5A.jpg[/IMG]
Old Aug 7, 2006 | 03:24 PM
Jezcruzen's Avatar
Jezcruzen
Yeah, that makes sense. I didn't think about pulling out and separating the speedo wire from the other two!
Thanks
Old Aug 7, 2006 | 03:51 PM
thugged's Avatar
thugged
Jezcruzen,
The signal wire for the tachometer...usually yellow, would go into cavity number 3 on the plug that connects to the speedometer. You will need a special terminal end ...HD part # 74196-04 to put on the end of your signal wire. I hope this helps.
Old Aug 7, 2006 | 06:01 PM
Woodyheritage's Avatar
Woodyheritage
I have an 03 flstci and there is a pink wire loose by the speedo or on some located in the headlight bucket. Hope this helps.
Woody
Old Aug 7, 2006 | 07:40 PM
Jezcruzen's Avatar
Jezcruzen
Thanks, Thugged. Yeah, I pulled my console last night and looked it over underneath. It was a little confusing regarding exactly where that lead was supposed to attach.
Unfortunately, that particular lead with the special attachment point for the speedo was missing from the box. I had to go by the dealership today to have them order a replacement. They told me it would take FIVE DAYS!
BrianK
Feb 15, 2022 07:53 PM
Eric The Welder
Feb 7, 2010 10:25 AM
BrockRKC06
Aug 28, 2007 12:03 PM
stgbrook
Mar 24, 2007 10:24 PM
flstfjeff
Nov 12, 2006 06:42 PM
