Im being told my bike has a EVO primary cover can this be??? It has a o-ring gasket for the derby cover thanks.....and it has 3 bolts holding derby cover
Only difference in the post-99 Primary covers IS the 5-hole derby cover. Inner primary was the same from 1995-2006. If it's not an after market, could've came from the MOCO that way.....stranger things have happened.
The Darby cover on 07 and up Twin Cam's has and O-Ring and is slightly higher on the outer primary.
They also eliminated the primary chain adjustment inspection cover on them because of the new auto adjuster system.
I have a 2005 Standard with an Evo Primary cover as well. My derby cover has 3 holes instead of 5 holes like the twin cam motors have. I say yes, these cover do fit on twin cam motors.
Softail inner primary is the same from 1994-2006, stands to reason that an outer from those years will interchange. The only difference is the derby cover.
Your bike has a Twin Cam engine.
Your bike has a three hole derby cover.
Thus...a three hole Evo style primary cover WILL fit a Twin Cam.
ok thanks ..I get so many people walk up to me and ask what year the bike is lol they get all messed up when they see the EVO cover lol
