View Poll Results: How many miles did you get from your engine before major repairs were needed.
20K
0%
40K
0%
60K
0%
80K
0%
100K
0%
110K
0%
120K
0%
130K
0%
140K
0%
150K OR MORE
100.00%
Voters: 1. You may not vote on this poll
Engine Lifespan
Old Apr 28, 2013 | 03:46 PM
  #31
skiddd's Avatar
skiddd
Originally Posted by Just Don
When I did mine I was not aware of any after market option. I went hydraulic because it came with a better oil pump as well. Please share the after market link when you can.
Here you go Don......
http://www.harleydavidsontensioner.com/
Old Apr 28, 2013 | 05:45 PM
  #32
coolflames's Avatar
coolflames
When bought my 2002 fxst it had 32k we took of the cover to check the tensioners. They looked real good, too good. My friend is a really good hd mech, for about 35 years. He said lets change the oil. When i pulled the plug on the oil tank nothing came out. He said did you ever change the oil? I said yes 200 miles ago. He says i know what is going on. We took out the plug in the crank case and out comes 3 qts of oil. He says the particles from the adjusters had plugged up the scavenge side of the pump. So i went with the gear drive set up . He said you will probley never have to take the cover off again. Basically turned the bottom end into an evo with 2 cams.
Old Mar 4, 2014 | 08:43 PM
  #33
Just Don's Avatar
Just Don
Just past 81,000 on my 05 Heritage. Still running Amsoil for all lubes. Keeping my fingers crossed.
Old Mar 24, 2014 | 09:11 PM
  #34
Just Don's Avatar
Just Don
Pushing 83K now. Had an unsuspected front sprocket failure during Bike Week in Daytona. Can't quite figure out how all those splines could wear away to nothing.
Old Jan 6, 2015 | 07:09 PM
  #35
Just Don's Avatar
Just Don
At 93K now with no engine issues. Still purrs like a kitten....well maybe a Big Cat.
Old Jan 7, 2015 | 08:34 AM
  #36
oct1949's Avatar
oct1949
Originally Posted by oct1949
41k on our 07,, so far I've replace one filter and gas line inside the tank and a new battery, thats it, well, also 7 tires and 3 sets of brakes...
Now with almost 53 K and she's running as strong as ever.. Not a single issue since the pin hole in the gas line 4 yrs ago..
maintained righteously I see no reason not to go another 100K... and now at 65 this will prob be my last one.. but I never know...
Old Jan 7, 2015 | 01:13 PM
  #37
GibT's Avatar
GibT
Thanks for the updates Don.
Old Jan 7, 2015 | 02:57 PM
  #38
Superrust's Avatar
Superrust
One of the few threads where resurrection has benefits. First time seeing this one and figure I'll jump in.
I'm riding a '13 Slim and doing the 15K maintenance right now (yes it's at 15K currently). At this time there have been no issues with the bike.
Outside of having it Dyno tuned to add more fuel, there are no internal engine mods (not expecting too). I use Purple Synthetic in 2 holes and HD Synthetic in transmission. I always change fluids per manual and in between if headed out on longer trips where a lot of miles are being added in a short period of time.
Thanks for the updates all, it's good to see what's going on with other bikes.
Old Jan 8, 2015 | 07:23 PM
  #39
Just Don's Avatar
Just Don
Been through two fuel lines and filters, and one fuel pump related plastic piece that allowed fuel to gush in the tank causing very little pressure. Happened all at once, almost stranding me. The part was cheap, but still had to pull the assembly. Both fuel line issues were pin hole rub related. The second one I put a larger clear vinyl tube over it before inserting it in the tank.
Old Jan 8, 2015 | 07:26 PM
  #40
Just Don's Avatar
Just Don
Ran Harley Syn 3 for the first 10K, then switched to Amsoil in all three holes every 5K. Any time I have removed a cover for any reason everything is clean and shiny.
