Vehicle Speed Sensor ?
Old May 9, 2010 | 07:27 AM
2003chromefatboy's Avatar
2003chromefatboy
Question Vehicle Speed Sensor ?
Tried this on the do it yourself forum, hope to get help here. 03 fatboy, efi, speedometer down, no directional cancel. Research on this site points to VSS. The problem is the plug is in a hard to reach spot, and the old one does not want to let go. I don't want to damage the wire harness end. Do you push or pull the tab on the wire harness side? Any help would be appreciated. Thanks. Chris
Old May 10, 2010 | 01:45 PM
50ronnie's Avatar
50ronnie
The VSS is in there with a rubber o-ring. Move from side to side and twist gently and it WILL pop out. I had erratic speedometer readings and pull mine. There is a magnet at the bottom that collects small metal shavings that interfere with the readings. Just wipe with a paper towel and reinstall.
wattey1947
Jun 13, 2018 01:12 PM
Dcruz84
May 17, 2018 11:05 PM
Razorback58
Electrical/Lighting/Alarm
Oct 29, 2017 05:51 AM
Jerzmatic
Feb 7, 2011 05:30 PM
wildside41
Apr 12, 2007 09:01 AM
