inside primary cover
Old May 9, 2010 | 08:23 PM
outlawrider's Avatar
outlawrider
Default inside primary cover
has anyone ever stripped the drain plug? can you tap it out to the next size bigger? or what would be a good way to fix it without replacing it?
Old May 9, 2010 | 08:53 PM
SurfRiderNC's Avatar
SurfRiderNC
How bad is it stripped? There is a number of thread repair kits out there that may get you out of your problem.
Go to your local auto parts store and ask questions. I did a quick Google search and came up with a bunch of easy to use kits.
Old May 9, 2010 | 10:46 PM
IronAss's Avatar
IronAss
Helicoil. Used to use them allot on shovelheads for the exhaust bolts and they work well for spark plug holes as well.
http://www.helicoil.in/
Old May 10, 2010 | 03:19 AM
hpfatboy's Avatar
hpfatboy
+1 on the helicoil, they truly are a SAVIOUR! It should be the same, if not stronger when your done!
maineultraclassic
Sep 15, 2016 06:25 PM
laserman2431
Sep 21, 2012 02:24 PM
Dino M
Nov 7, 2010 06:05 PM
OneBlackFly
11
Sep 29, 2009 11:51 AM
dert
EVO
Jan 12, 2007 03:01 PM
