POWER COMmANDER 5 IN FAT BOY INSTALL?
Old May 17, 2010 | 05:07 PM
coronerrpm's Avatar
coronerrpm
Default POWER COMmANDER 5 IN FAT BOY INSTALL?
Got the power commander and air cleaner system from fuel moto today. Has anyone put the commander 5 in a fat boy? If I remember when ordering it they said it was not the same install and some extra steps need to be done for it to fit under the seat of a fat boy but never said what they were. There is not a hole lot of room for it under the seat.
Old May 17, 2010 | 07:05 PM
flynhigh56's Avatar
flynhigh56
I have one on my 09 and no, it didn't fit under the seat. I had to put it behind the rear fender. It was not that big a deal and the benefits of the Power Commander are well worth it
Old May 17, 2010 | 07:12 PM
streeteagle's Avatar
streeteagle
Installed mine in my '07 Deuce a few days ago. It does't take up much room, my directions said to mount it on top of the battery. I had to slide mine in behind the battery. I also had to slide the security module over to the side. After you make all your connections, mount the ECM as far down the fender as you can. After you get everything connected & mounted, install your seat. If it does'nt fit down like it should you may need to make some minor adustments so no part of the seat is resting on anything.
Old May 17, 2010 | 07:13 PM
streeteagle
Is your a model 3 or 5?
Old May 17, 2010 | 07:22 PM
Flintstone1's Avatar
Flintstone1
Coronerpm could post your results after your install? It's would benefit all of us with the newer fatty's. I'm looking at the same setup from fuel moto.
Old May 17, 2010 | 07:28 PM
jed1069's Avatar
jed1069
Mine is in an 09 Fatboy. It will fit under the seat. Here are a few pics.
Attached Thumbnails POWER COMmANDER 5 IN FAT BOY INSTALL?-pcv1.jpg   POWER COMmANDER 5 IN FAT BOY INSTALL?-pcv2.jpg
Old May 17, 2010 | 09:01 PM
bucholj's Avatar
bucholj
Here is a thread I started a little while ago, a few forum members were kind enough to post some pics to help me out.
https://www.hdforums.com/forum/softa...tallation.html
Old May 17, 2010 | 10:04 PM
flynhigh56's Avatar
flynhigh56
I have a PC 5. Mine wouldn't fit under the seat. I don't have a stock seat and I'm guessing there are slight clearance differences from one seat to another.
Old May 18, 2010 | 04:05 AM
coronerrpm's Avatar
coronerrpm
I will post some pics today after I install it. No time last night to do it.
Old May 18, 2010 | 07:35 AM
coronerrpm's Avatar
coronerrpm
I took about an half hour for both the PC-5 and air cleaner. I can't find the cable to up load pics but mounted the ecm sideways and it fit that way. Hope that helps.
chunks
Sep 25, 2010 11:03 PM
aqua754
Jan 24, 2009 02:30 PM
Rattbone
Mar 13, 2008 09:20 PM
Skullman3
Mar 13, 2006 09:38 PM
