Highest compression using the stock starter????????
Old May 19, 2010 | 08:20 AM
Mario77746's Avatar
Mario77746
Default Highest compression using the stock starter????????
I'm finally getting my 95" big bore kit installed and need to know what the highest compression I can still run the stock starter? I'm going to be somewhere between 9.5 and 10.25.
I figure there are 2 options if I pass the threshold:
1. Upgrade to a bigger starter. What size?
2. Compression releases installed once the heads are off and at the machine shop. Anyone ever do this?
Thanks.
Old May 19, 2010 | 08:32 AM
lionsm13's Avatar
lionsm13
10-1 no more.
Old May 19, 2010 | 08:52 AM
Rockyriver's Avatar
Rockyriver
lionm13 hit it dead on the head at 10:1.
Usually a stock starter will start to grunt at anything above 10:1. I have seen stock starters crank engines with much higher compression, however Its all in how the stock starters built, some are just stronger than others.
Old May 19, 2010 | 09:57 AM
I CUT 1's Avatar
I CUT 1
I'm in that 10.25 realm and I went with the Harley S/E releases. The starter will crank it up with out using them, BUT, it does't like it one bit. Get the compression releases installed while it's torn down. Hell of a lot cheaper than a new starter.
Old May 19, 2010 | 10:29 AM
NCTURBOS's Avatar
NCTURBOS
Definitely have the machinist install compression releases, Goodson has some good ones. I'm at 10.8:1 compression with the original starter and cables, but am bumping that to 11:1 now. Down the road I'm planning on upgrading the starter and just as importantly the cables...
K.
Old May 19, 2010 | 06:12 PM
snip0721's Avatar
snip0721
10:1 is about the limit. stock starter will work at a higher comp. BU NOT FOR LONG. releases are a no-brainer when the heads are off. when its time for a starter go with a better than stock replacement. better cables sure wont hurt either. steve
Old May 19, 2010 | 06:16 PM
snip0721's Avatar
snip0721
also depends on camshaft choice. use one of the calculators to figure your final comp. steve
LDB187
Mar 3, 2014 08:50 PM
Lundee
Exhaust System Topics
Mar 19, 2012 12:48 PM
hd0wner
May 24, 2011 12:32 PM
Bluesrider
Jan 6, 2010 11:32 AM
turbo38sfi
Mar 14, 2007 06:53 PM
