Help with heritage
Old May 29, 2010 | 10:35 AM
oldryder's Avatar
oldryder
6th Gear
Default Help with heritage
I'm trying to help a friend get her 2000 heritage running. It has been sitting for awhile but ran before. although it was hard to start. Put a new battery in it. It checked out at 12.7 volts. Tried to start it, nothing. Turns over fine, is getting gas. Pulled the plugs to check for spark no spark at all. Where, what do I start to check? Thanks
Old May 29, 2010 | 12:18 PM
grumpygy's Avatar
grumpygy
Check the coil and see if its getting voltage.
Old May 29, 2010 | 12:54 PM
oldryder's Avatar
oldryder
6th Gear
will do. what voltage should i get?
Old May 29, 2010 | 01:22 PM
DaddyKnuck's Avatar
DaddyKnuck
You can also pull a sparkplug, put it back in it's cap and make sure it's in contact with the head. Crank the engine and you should get a nice fat spark. Make sure the kill switch is in the run position. You wouldn't be the first.
Jiggyj96
Jun 1, 2017 10:26 PM
98harleyman
Oct 24, 2014 07:10 PM
Ratbike_Mike
Aug 20, 2014 11:30 AM
grat
Nov 12, 2008 02:21 PM
Snipman
Mar 12, 2008 09:56 PM
