question bout Security Light
Old May 29, 2010 | 08:06 PM
Scheers44's Avatar
Scheers44
Default question bout Security Light
Got an 07 nightrain and the Security lights come on and seems to wanna stay on any one tell me what this means? I'm away from home and was hopin to find an answer before I get home and go diggin through my books. Thanks again.
Old May 29, 2010 | 09:51 PM
rdoucet's Avatar
rdoucet
I have an 07 Night Train as well and had the same issue you had when I bought it used.
My issue was that the security light would not shut off and turn signals flashed fast. Previous owner put in led lights in rear and ecm saw this as a burned out bulb; lights (turn signals) would flash slow 3 times then go fast. Also, 6th gear would not show up on speedo when I was in 6th gear.
Soulution was to go with a Badlands load equalizer III. I checked Dennis Kirk website and part number is LE03A; Dennis Kirk number 214282.
This is a solid state unit and solved my issues with the bike. Signals flash normal now, security works and light goes out.
I only gave you Dennis Kirk numbers because I was able to access their website. I know their are dealers on this website who also are sponsors of the hdforum that stock this unit also.
Hope this helps
Old May 29, 2010 | 10:00 PM
Scheers44's Avatar
Scheers44
Well I do have LED rear turn sigs which didn't cause any issue, but the new Pro1 triple tree with integrated sigs prob set it off than
Old May 29, 2010 | 10:08 PM
rdoucet's Avatar
rdoucet
The badland load equalizer I purchased is plug and play - no cutting into the wiring harness. I would go with the load equalizer and this should solve your problem.
Old May 29, 2010 | 10:10 PM
Scheers44's Avatar
Scheers44
Where does it plug in??
Old May 29, 2010 | 10:14 PM
rdoucet's Avatar
rdoucet
Under the seat
If you are looking at the ecm the connector is to the left (exhaut side) of the bike behind the battery. This connector is under the seat by the battery, not on the side of the bike. Load equalizer has instructions with it that show the harness and the location.
Very easy to intall.
Old May 30, 2010 | 10:49 PM
tc1816's Avatar
tc1816
Does anyone know if the Badlands load equalizer III Dennis Kirk number 214282 will work on my Rocker. I have led front blinkers and they blink fast.
Atlantaclassic
Electrical/Lighting/Alarm
Dec 12, 2017 08:58 AM
ajnigli
Jun 5, 2017 05:13 PM
SOCALLOWBOY
Jul 27, 2012 11:29 AM
parrothead306
Sep 23, 2009 10:17 PM
Muddyape
Mar 25, 2008 02:42 PM
