5k Service DIY?
Old Jun 2, 2010 | 11:47 AM
Twofields6's Avatar
Twofields6
Question 5k Service DIY?
I need to do the 5K service on my '09 Heritage Softail Classic. Would like input on difficulty, tools needed, things to watch for, etc. Love the dealer I got it from but don't want to pay the minimum $300 cost if I can do it myself.
Old Jun 2, 2010 | 11:55 AM
Tucson_Tim's Avatar
Tucson_Tim
You may know this already but the H-D service and parts manual are highly recommended (well, more like necessary)
You will need a long reach 1/4 in hex key socket to access the transmission plug, up between the shocks.
You will need a good set of Torx sockets, expecially T-27 to remove primary case cover. T-handle or "L" wrenches may work but you will run the risk of stripping the heads.
I've re-used the large O-ring on the primary cover and the O-rings on the three drain plugs but it is not recommended -- buy new ones.
At least two torque wrenches (ft-lbs and in-lbs). The bar-type torque wrench is kind of difficult to use when tightening the drain plugs, since it will be upside down.
Teflon paste for the three drain plugs.
A lift or wheel chock setup to hold bike (safely) verticle.
Buy (or rent) the "Fix My Hog" DVD -- good info there.
Old Jun 2, 2010 | 11:56 AM
Six Gunner's Avatar
Six Gunner
First and formost, Spend 60 bucks on the service manual for the bike for it will guide you through every step of the way. If you stray there are plenty of people here that will set you right back on course.
Old Jun 2, 2010 | 12:02 PM
DR. V-TWIN's Avatar
DR. V-TWIN
Former Sponsor
Manual is a must. You can use an extension on a ratchet and a regular 5/8" socket if you prefer for the transmission drain, at least on my 2002.
Drew
Old Jun 2, 2010 | 12:04 PM
Tucson_Tim's Avatar
Tucson_Tim
Drew
You're right Drew. That will work better and it's better with the torque wrench.
Old Jun 2, 2010 | 12:06 PM
Tucson_Tim's Avatar
Tucson_Tim
Originally Posted by Twofields6
. . . don't want to pay the minimum $300 cost if I can do it myself.
That price actually sounds pretty reasonable for the 5K svc. I've heard of dealers charging $400+ for the 1K svc.
Old Jun 2, 2010 | 12:09 PM
Tucson_Tim's Avatar
Tucson_Tim
Although some folks do it by feel, you will need the H-D belt tension check tool -- it's not expensive, maybe $20.
Old Jun 2, 2010 | 12:50 PM
oct1949's Avatar
oct1949
don't forget the spokes needs checked and oil the cables.
Old Jun 2, 2010 | 01:20 PM
Bossman1's Avatar
Bossman1
Manual and U r ready to b ur own service tech!!!!!!!! Stealer has never seen mine!!!
I am sure u got a gud buddy that can guide u through it.It is a piece of cake......
Old Jun 2, 2010 | 01:36 PM
Tucson_Tim's Avatar
Tucson_Tim
You'll need an oil filter wrench to get the filter off. Now, H-D recommends a strap wrench and I have one of those but I prefer the end-cap type. It has a 3/8 square drive hole. I bought it for $3 at Auto Zone.
Here's an example:
http://www.sjdiscounttools.com/lis54740.html
Take your oil filter to Auto Zone and find one that fits the end.
NOTE: Don't use wrench to put filter on. Hand tighten only.
