**Noise While Slowing Down**
Old Jun 3, 2010 | 08:55 AM
Notorious688's Avatar
Notorious688
Alternator?
Old Jun 5, 2010 | 07:44 AM
handyhoward's Avatar
handyhoward
If you are sitting still in neutral and you rev the bike do you get this whine? If so rule out anything in the drive train ie belt or wheel bearings. If the whine is still there, the possible problem is one very well known to HD and it's reputation for cheap *** parts... I would definitely check out the cam shaft bearing and/or bushing.
Old Jun 5, 2010 | 11:49 AM
Notorious688
Yes, my bike has the whirring noise when sitting still and if I rev the engine, I get the spinning sound in the engine bay.
Old Jun 5, 2010 | 11:52 AM
JayDee5150's Avatar
JayDee5150
Sounds like a loose drive belt to me...check your belt tension.
A loose drive belt will whirl and whine on deceleration, almost sounds like a turbine.
Old Jun 5, 2010 | 01:51 PM
handyhoward
Like I said... rule out the drive line, belt, wheel bearing, etc. if it is whining while sitting still. None of those parts are moving... could be cam bearing(quite common in Harleys... could be primary chain... could be stator.
Old Jun 5, 2010 | 06:07 PM
scubadnv's Avatar
scubadnv
I had that happen after having a rear tire replaced and after inspecting the indys work found the drive belt as tight as a piano string. Adjusted the belt to spec and no more noise.
06Softail
General Topics/Tech Tips
Oct 9, 2018 04:58 AM
stevefxdi
May 11, 2013 09:30 PM
Bluehighways
Jul 22, 2010 08:30 PM
timebandit60185
Jul 15, 2009 10:31 PM
veniculum
Aug 21, 2006 06:19 PM
