Fuel management system.
Old Jun 3, 2010 | 11:17 PM
oct1949's Avatar
oct1949
don't like the piggy back,, 4yrs ago the SERT was as good as any,,,now theirs more to choose from....
Old Jun 4, 2010 | 04:52 AM
texas-buzzard's Avatar
texas-buzzard
With the TM, the AFR can be set anywhere you want it at different TPS and RPM. This give you the ability to get more power when accelerating and better fuel mileage when cruising. I get 48-50 mpg on the highway.
Old Apr 7, 2011 | 09:54 AM
bigbopper's Avatar
bigbopper
6th Gear
OK better late than never.....I finally broke down and sold the PCIII and installed the Thundermax with Autotune. Nice little package, very well made.
Since there seems to be many of you with a similar set-up to mine, what base map are you guys running, there doesn't seem to be an exact component match in the T-Max list?
I know it only needs to be close, but wouldn't mind some opinions...
Would a dyno offer any better tuning of the T-Max, specifically in terms of the timing map?
Thanks,
BB
Old Apr 7, 2011 | 10:13 AM
cpiad's Avatar
cpiad
Account Closed
Originally Posted by fishcop
In my humble opinion the Thunder Max or T-max is the best. It is a direct plug an play replacement for your stock ECM. With the Autotune, which I recommend, you simple download a map as close as you can to match your components and then ride. As you ride the auto tune does it's thing and fine tunes the ecm. It also has features that you can adjust with a laptop computer for even finer tuning. I installed one on my 07 Ultra installed a map and WOW what a difference. No more pinging, and the heat was finally bearable. I have also read some posters liking the HD SERT which is a software download so you have no "piggyback system" to worry about. But with the SERT you probably need to Dyno the bike. If you can hold of a recent issue of American Iron Magazine they are doing a whole series on tuning EFI HD's. One other point, the T-max is not cheap about $850-900. I know Cateye Customs, a forum sponsor, sells them. Anyway just my $.02 worth.
I would pretty much agree ... except that Zipper's refuses to update the firmware and provide a modern cable. They insist on using an old RS232 connection ... and you will not find an RS232 (9 pin) serial connection on any notebook/laptop made in the last three three years or so. And .. Win 7 and Vista hate the cheesy drivers provided by the Sabrent USB-to-RS232 Cable Zipper's is happy to sell you. I had to buy an Express 54 RS-232 adapter card for reliable communications. Some people on this forum will tell you that is not a problem .. maybe they have old notebooks ... maybe they are lucky ... lots of idiot savants are just lucky that way.
Keep in mind ... if you place any value on your warranty ... and if you have a new bike ... you will lose warranty coverage when you install to the Zipper's T-Max. If you want to preserve your warranty ... go with a SERT and Mastertune software ... have a stealership install it ... and off you go. Me ... I don't give a darn for HD warranty .. I buy a bike .... I pay the least I can ... and I never, ever take it back to a dealer ... NEVER.
And .. the Auto Tune is not the end-all/be-all answer and it sure as heck does not obviate a good dyno session no matter how you are managing fuel ... the Auto Tune module really only provides a little AFR self-control .. it will not get rid of pinging due to poor mismatch between your baseline map (maps prepared by Zippers by dyno runs over many different bikes and mod setups). I started out with a file that best fit my bike ... and I am still working with it. Like you ... I had lots of ping with the Thundemax .. sounded like a can of marbles shaking .. and that is with the best fit starting basemap. I worked like hell to make it better and I posted the file I was using on this forum .. but due to inane and idiotic remarks from "know-nothings" with too much time on their hands .. probably only bikes they have ever owned are Big-Wheels... I pulled it fromt the forum. Too many know-it-alls on here.
If you ride like an old lady ... a T-Max may help .. but if you ride like me .. I ride a bike like I stole-it ... then you are in for some work with a T-Max.
Get a SERT and Mastertune ... save yourself some grief and time ...
Old Apr 7, 2011 | 10:26 AM
bigbopper's Avatar
bigbopper
6th Gear
And .. the Auto Tune is not the end-all/be-all answer and it sure as heck does not obviate a good dyno session no matter how you are managing fuel ... the Auto Tune module really only provides a little AFR self-control .. it will not get rid of pinging due to poor mismatch between your baseline map (maps prepared by Zippers by dyno runs over many different bikes and mod setups). I started a file that best fit my bike ... and I am still working with it. Like you I had lots of ping with the Thundemax .. sounded like a can of marbles shaking .. and that is with the best fit starting basemap. I worked like hell to make it better and I posted the file I was using on this forum .. but due to inane and idiotic remarks from no-nothings ... I pulled it fromt the forum. Too many know-it-alls on here.
Thanks for your input Cpiad.
Too bad, I would have liked to have followed your mapping progress. Unless I find major issues, I will be keeping the T-Max, although I agree with your opinion on the archaic computer cables etc....
As for warranty, I could care less....customer service from HD in my area sucks and I am way too **** to let them touch my bike...I do all my own work anyways...
Have you had a dyno session, or just working through it yourself?
Cheers,
BB
LazyLion
11
May 9, 2021 10:26 AM
younggeezer
Oct 30, 2008 07:28 PM
jsbridgew
May 22, 2008 09:35 AM
SE120RG
Mar 30, 2008 11:43 PM
JohnK/Pa
13
Jan 31, 2007 10:17 PM
